Project AA.
Started by Auto Addict, 07 August 2010, 07:04:13
Auto Addict
Forgot to mention, re-seated the tubes at the back of the plenum, clicked the eco strip home by the last couple of mm.
Running like a dream now (nearly as quick as my old 2.2) ;D
I like red cars
Welung666
QuoteForgot to mention, re-seated the tubes at the back of the plenum, clicked the eco strip home by the last couple of mm.
I thought that might have been the case  :y
Auto Addict
To flush or not to flush?
2nd oil change after 200 miles was as black as the ace of spades.
What do you recon?
I like red cars
Id just stick to some low mileage changes....its what im doing here  :y
Auto Addict
QuoteId just stick to some low mileage changes....its what im doing here  :y
Yes, I don't like flushing engines.
Recon it would be a good idea to take the sump off, and give it a good clean out?
I like red cars
Seems to be a bit of a trend of it at the mo....shouldnt hurt and you know that pickup pipe is clear.
Im thinking some oil changes till you get a few thousand miles between changes, then clear out the rest of the crap manually may be an idea  :-/
Auto Addict
You've got the job! ;D
I like red cars
45mph? :o
I too vote lots of short oil changes....
Auto Addict
45mph? :o
When you drove it, you only did 25 mph :D
I like red cars
Auto Addict
Strange, for a short period today, the central locking worked off the key fob :-/
I like red cars
Auto Addict
QuoteStrange, for a short period today, the central locking worked off the key fob :-/
Working again today.
Is it because I've been spraying the lock mechanism with liberal amounts of silicone lubricant?
Time will tell.
I like red cars
Auto Addict
Right, I'm about to change my front brake pads, is there anything I need to know?
I like red cars
erm, 1 that springs to mind is open the bleed nipple before pushing the caliper back in, gets rid of more old fluid, and reduces risk of inverting the master cylinder.  :y
Auto Addict
Quoteerm, 1 that springs to mind is open the bleed nipple before pushing the caliper back in, gets rid of more old fluid, and reduces risk of inverting the master cylinder.  :y
Got no brake fluid, left it at Marks :(
I like red cars
