Shackeng
Took the TD Estate to the body shop for a little bodywork TLC. :)
Fitted leather gaiters to the gear and handbrake levers to replace the shabby vinyl originals
Shackeng
Quote from: Nick W on 23 May 2015, 14:03:38
I'd like some of these, where from Nick? :y
Delroy47
That's better put some chrome exhaust tail pipe trims on the ETS system  :)
Covered a idiothead beemer in my soot. Much to his annoyance.
That's not what I typed. Whats wrong with idiothead?
chrisgixer
chrisgixer
Oh, that's not what you typed then. ;D
pauls
Wasted 3 hours of chrisgixers time trying to solve my issues :'(
EMD
Sprayed me sill end cap black , am knackered now  :(
Omegatitis
chrisgixer
Quote from: pauls on 23 May 2015, 18:38:24
Oh no not wasted Paul don't worry. We fitted new(er) plugs and checked the HT system. Noted some minor water ingress, probably from the scuttle drain over pot 6 ( you need to seal that up btw)
Checked trims and maf ouput and found no issues there, afaict. No codes in gear box, abs or engine ecu's. Solenoid tests all seemed fine.
The slight miss or drop in power I witnessed last time didn't happen after.
However the slight oddnes on shift quality was evident, as was the jumpy rev counter needle when blipping the throttle from tick over. Although that never returned after the codes where cleared and trims reset.
How was the journey home? Any issues?
ffcgary1
Replaced the clutch on a skoda fabia 57 plate with only 33,000 miles on the clock, :o previous owner clearly used the pedal as a foot rest. >:(
Jaguar XJ6
Quote from: Shackeng on 23 May 2015, 15:17:47
Ebay of course. http://www.ebay.co.uk/itm/FITS-OMEGA-C-99-03-LEATHER-GEAR-SHIFT-HANDBRAKE-GAITER-/390774156928?  £12 for the pair. You'll need some contact adhesive, and a sharp blade.
They look much better than the stock ones.
Quote from: chrisgixer on 23 May 2015, 20:24:48
Weren't LTFTs a bit off, albeit not by much, but show there may be a potential issue?
Ideally, the LTFTs need checking after a couple of hundred miles now they have been reset.
After fitting the gaiters I made an aluminium gearknob for a friend's Astra as he forgot to order one with the quickshift kit. Putting the radius on the top by plotting it in 2mm steps and then filing/polishing to a finish is a good prompt to finish the ball turner I started last year.
