ffcgary1
Changed the plugs today as they were about 7 years old and i had a missfire so a good chance to investigate that, found centre plug on the drivers side and ignition lead covered in oil so a change of cam cover gaskets needed.
Also changed the AUX water pump below the coolant bottle as it had burnt out and almost cought fire, lucKy as it was only the pump and not the plug and loom. :y
Gary.
Jaguar XJ6
minifreek
Refurbed the headlights as they was beyond polishing with a bit of compound etc...
So tried flatting them back with some wet and dry then resprayed them with clear 2K lacquer...
They've come up a treat and look like new :)
D.I.L.L.I.G.A.F...
The lacquer coat is a total waste of time and money as the heat from the lights will cause it to yellow and ultimately burn off...
The lenses aren't lacquered new, the fading etc is caused by UV degradation of the surface of the ppastic ;)
minifreek
Its OK Al, Im not worried about them going yellow or flaking... thanks though :y
D.I.L.L.I.G.A.F...
Shackeng
Did a twenty minute trip and found that another four manufacturers are now owned by BMW, as they were sold without the optional indicators. >:(
Shallow Al
Changed abs ecu. Doesn't look too bad to start with, but soon looks impossible. Solid determination and patience win the day, and all lights are out. Now for MOT. :y
I used to know everything. Then I got married.
minifreek
Got almost all the parts for this weekends HG job to do.... before we drag our tintent away to the lakes for the week :)
Need to get me some oil and a filter yet....
D.I.L.L.I.G.A.F...
chrisgixer
Had it re gassed. All good no leaks after re using o rings for the new condenser.
Took delivery of some super sports. :) ...after a bloody week!  >:(
The Sheriff
Quote from: chrisgixer on 18 May 2015, 21:48:42
Some super sports what?  ;D
minifreek
Its Gixer... what else would they be except tyres.... :y  ::)  :P
D.I.L.L.I.G.A.F...
chrisgixer
Quote from: STMO on 18 May 2015, 22:13:55
Mpss of course ::) come on Steve. Don't you know anything? ! ;)
chrisgixer
The Sheriff
Quote from: chrisgixer on 18 May 2015, 22:20:16
Mpss...ermmm....right you are  ;D
Shallow Al
chrisgixer
#10214
Michelin pilot super sports 245 40 zr 18 97 y mo.
Edited. Forgot the zr  :-[ ;D
