Took of the calliper mounting bracket on the Battlebus, and attacked it with the grinder, to sort out the brake binding.
Went over to see chrisgixer to program up a replacement engine ECU - one of those 10 minute jobs that took over 3hrs ;D.
Whilst there, was going to tighten up rear wiper arm on the Battlebus, as it keeps adjusting itself.  Removed the cover, and immediately noticed no amount of tightening was going to fix it ;D
Got home, ordered new rear wiper arm for Battlebus :P
Fitted the full steering column to the Cobra - it now steers when you waggle the wheel, hurrah!  Had to reduce the length of the intermediate shaft to suit (it does say to do that in the manual) and wanted to do it neatly, so .. decided I'd spend the hour to throw a motor back on one of the little lathes.
Eet verks! https://youtu.be/QaWcc4myVwU
I mean, I couldn't find a parting-off tool in my pile of tooling, nor could I find enough of the right shims to get the tool I did find correctly on centre, and there's enough play in the compound slide that it jumped a good twenty thou up and down at times.. but apart from that it got the job done ;D
Quote from: tunnie on 24 March 2017, 20:22:19
Quote from: RumpelStiltSkin on 24 March 2017, 20:16:35
Today I have been abusing the Battlebus on steep, narrow roads.  Mullered the brakes, and knackered the economy, but its behaving remarkably well.
Could definitely have used those missing horses today though, so need to have a poke around the turbo when I get home, along with grinding down the caliper mounting bracket to make the pads sit a little better on the back.
You know you could just get something decent and new and not spend 80% of your time repairing 3 rusting wrecks  ;D
Tunnie, you have spent the best part of ten years on here pointing out the stupidity of taking depreciation on the chin........yet when you buy (one of the dullest cars on the planet).......your tune changes..... ;D ;D ;) :y
Quote from: Marks DTM Calib on 27 March 2017, 11:14:57
Times change, when I started I was a student and could spend all day tinkering without any issue. Time is a luxury now, I have zero spare time at weekends to spend crawling under cars.
Now owning a house, 2 cars, looking after MrsT and Little MissT and no longer doing shift work, I can't spend weekends under a car.
Contemplated washing it and taking pictures with a view to selling it, but both would require getting out of bed ::)
Shackeng
TD Estate passed its MOT again. Will be up for sale shortly with a year's ticket. :y
Quote from: tunnie on 27 March 2017, 11:37:18
Yet everybody else manages to find time.  I too own a house, own 3 cars, and don't do shift work.  Yet I have time, despite the fact I suspect I have far more demands to deal with.
We all have choices, and yours is to take your car to those nice, honest people at VW, because there are awfully trustworthy, and pay their very reasonable charges to change the oil (and maybe even the filter if you're really lucky). You are prepared to lose that money in depreciation and running costs, in return for a badge on a vehicle that's hard to desire or justify.  As said, that's entirely your choice :y
But please stop berating everyone who can manage their time and dare I say even enjoy working on their cars, as you have for the last 10 years.  That's their choice :y
Quote from: RumpelStiltSkin on 27 March 2017, 19:25:22
What he should have said was 'I've got more enjoyable/important things to do than crawl under cars at the weekend'. That makes perfect sense.
I used to like tinkering, now I don't, so I let someone else do a service once a year. No brainer, really.
neil74
Changed the water pump earlier. and hopefully the coolant wont all leak out again like it did previously
Zirfeld
Today I made a hole  :-\
Now I can check street condition directly beside my feet   ;) , but the Omega is a little noisy now. :o
Hope to find time to weld in my handcrafted repair sheet later this week 8)
direct upload
fotos kostenlos
Rolf
I am not forced to drive an old Omega. I simply like it.
Looked at it in disgust ::)
I suppose I'd better order a radiator for the replacement one. Question is, do I do the cam belt and water pump whilst it's apart... No proof of when it was done but certainly more than 4 years, although probably under 20k :-\
Or do I make sure it's going back on the road by MOTing it and then do the other work later, probably when swapping LPG over :-\
Quote from: Lazydocker on 27 March 2017, 23:25:07
I'd do this so that you have a list of priorities first, then you can make an informed decision.  :y
Quote from: Zirfeld on 27 March 2017, 23:15:38
Ah c'mon. Nobody is going to point out what shape the hole is? ;D ;D
Oh cock and balls, that was an opportunity missed by Stemo ::)
