noel
replaced the washer on the thermo cooling fan switch as rubber insert had perished and was leaking slightly,now going for a quick blurt down the bypass for a test drive to make sure  :D :y
doz
I'm running out of things to fix  :-[ :-[Well things that I can afford to fix. Why is there always so many days left at the end of the money  ;)
noel
Quote from: doz on 31 March 2012, 12:09:46
oh the joys of motoring  ;)
darkangel51n
Got water/sponge/shampoo carried bucket to car and.......watched while the wife washed the said miggy  :y :y :y
MaxV6
had a go at polishing headlamp lens on driver's side...     it's better than it was, but still not perfect.....  ouch my hands.... even with a drill loaded with apolishing head and some compound it takes some doing....
is there a how to on this???   if not why not?  :y
MaxV6
thanks rob... i looked in the wrong bit....
using a couple of  polishing heads, some care, and a couple of different grades of cutting/polishing compound , makes a huge difference....   what i've not been brave enough to do yet,  is take the wet and dry to the lens....      i'll save that for another day i think.....
Elite_L0ver
Jetwashed waxed and polished AGAIN!!!!! but looks good
Quote from: RobG on 31 March 2012, 15:03:17
http://www.omegaowners.com/forum/index.php?topic=90643.0
this next for the headlight to sort out  :y :y ;D  tomorrow  ;D :D ;D
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Tried to free off the stuck tie rod jam nut on the MR2.
Failed.
Grump.
2boxerdogs
Both O2 sensors & air flow meter replaced on the 2.2 , have a contact with a Tech 2 & replaced these on his advice car ran well before, but even sweeter now.
Cleaned the inlet manifold on my 2.2 DTi, not a very nice job at all, it was full of thick, sticky oil and exhaust soot :(
Pity you can't block the EGR on the Desmond Wheesel
Fitted new rear bushes to the AA's wishbones and re-fitted them.
Also did the cam cover gaskets on it
Sorted a seized HID level sensor actuator arm.
Need to bleed the brakes I think as they are a bit spongey!
Fitted charged battery on V6, just need to add fuel now!  ::) ;D
fixed a rattley door pin in big blue.
geoffr70
Quote from: Jimbob on 31 March 2012, 18:29:47
I need to do that.
Thought about that ^
Managed to break the 20 mpg barrier around town.
TC and BnQ Trade holder.
