buttsy19
Renewed the power steering fluid, as the old was like water and smelt rather burnt, next job is autobox fluid change, anyone know where i can get the gaskets from or are they cheap enough from the stealers.
If it aint broke, break it, then fix it
There's a chap in the back of the AutobahnStormers mag who sells the set of auto box gaskets plus filter for about £30 plus postage, if you're a member. :y
Too the front calipers off the Jag..
Damned if I can get the discs off, though  >:(
doz
Took for a drive to meet Omega Luver at the pub. Jolly nice it was to
danzigfan
Went on a trip with my family to visit my parents, 400 km, sweet driving, no problem, 14 years old omega drives like a brand new one. Can't stop loving it
grain.ben
replaced both front door strap bushes. hey presto, no more cracking noises!  :y
MaxV6
fitted replacement NCDC2013, and A CID ....   and then discovered a wiring fault....  intermittent CID...  mostly not working....   wiggling plug around and pulling loom  found that it worked only in a certain position....  so, loom chopped, spliced and plug replaced...  (huge thanks to RobG for having a spare one and the presence of mind to make me take it with me ! )
bingo it all works, and looks wonderful, FINALLY i can see what the sat nav is trying to tell me,  FINALLY i can actually read the trip computer data....    YAAAAYYYYY    chuffed to flippin bits////
casualties....   lost 1 screw down the steering column, another behind the vents,   and one of the steering column cowl screws has vanished....  need to visit a scrappy and obtain said screws....
and the NCDC doesn't have a broken front....  so no more rattle.... and it sits in the facia properly....      and the disc cart all works....   good grief i'm pleased !!!!
Glad you`re happy (or should I say overly elated ;D) Max. Nice to meet you. :y :y
Assume it was a dodgy wire in your loom then :-\
So was that why the last one didn't work...?
Quote from: chrisgixer on 24 March 2012, 19:26:05
Think it may have been a Vectra based jobbie Chris
Swapped the winter wheels for the summer ones - damn the alloys are heavy compared to the steelies with winter tyres!
Tried to undo the whip aerial again and gave up as it just goes round and round and round and .. whoops.
Donated a set of rear pads to a friend who turned up with his DTi making odd noises - that'll be because the 105,000 mile rear pads had disintegrated then.
And took this off the Jag:
(The axle set obviously, not the T56 6 speed in the picture ;D)
MaxV6
Well the thought has occurred to me,  gonna see if TB has a bit of time to play with it again....  the dodgy loom would definitely have screwed up the attempt to pair the CID....  so.....     it would cheer twiglet up no end if i could hand him a known workable unit at the essex meet....  or at least he'd know for sure one way or another....
also, even more thanks to  Rob for the battery......   will fit that tomorrow.....   much appreciated.....  (and the practice set of fog lamps for lens polishing experiments...  )
Elite_L0ver
Quote from: doz on 23 March 2012, 15:34:51
Yeah nice afternoon for it also went fir a meal with mrs lover and drunk too much give the mig a wash and polish tomorrow  ;D
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
martin42
fitted new rear box,had to break out the cutting equipment tho,luckily i have a long extension lead,and then popped over to corby to do eatmydust's thermostat and coolant bridge,so busy afternoon and evening but worth it  :y
