Macduff
Changed my wheels from old school prefacelift MV6 wheels to facelift Elite wheels :)
Born free taxed to death
DaveA
 Been giving all the tow bar electrics a good clean and checked they are working OK.
   What I did notice, is, that the rubber hangers holding the back box on, had perished and split, only put then on in Feb last year when replaced my exhaust, from Eternalcar. Replaced with the old VX rubber hangers, which are in better condition and a lot older, will replace all the others before MOT.
others seem OK at the minute.
Regards
    Dave
Quote from: DaveA on 08 April 2012, 15:59:13
The Eternal hangers are shite.  I only get the exhaust pieces from there, ancillaries from elsewhere.
Bought a set of new (to me) shocks and springs for the Westfield.
Went to a Westfield meet. 2 of us turned up in the proper vehicle. rather lightweights. ;D
Quote from: Kevin Wood on 08 April 2012, 17:17:13
Bit like the local ABS meet we have near here - only Mike Bloodworth and I turn up in Vauxhalls, let alone 'eligible cars' ;D.  The rest turn up in Audis, Porsche, Dodge Rams, transits etc ;D
amba
Spent several hours today fitting a new catalytic converter/down pipe with flexi to #1 daughters MK2 clit.
Why don,t aftermarket parts ever fit first time around :'(  Alignment holes for heat sheild is in totally the wrong place and the securing holes for the cat to the cars original bracket are a mile away.
Ended up having to remove the entire other 2 sections of the exhaust to get it all back in some sort of resemblance of a correct fit.In the process managed to shear off 2 out of the 3 bolts that hold the stupid ali rear box mounting .Now have to wait until Monday until I can get a couple of drill bits to get the busted bits out then hopefully it will be back together.Local speedy place wanted £185=00 to replace ,but managed to get part from Mr.Exhaust for £75=00 delivered so suppose I can put up with bit of agro .
Any exhaust fitters around that can answer this question for me.??
amba
Woops pressed button tooo quickly. ;D ;D ;D
When I removed the original cat/downpipe there was NO gasket between the exhaust manifold and the downpipe.Although pipe has a definite flange and sits tight to the manifold sure this cannot be a gas tight seal.   I have fitted waht was given in kit which looks like a "brillo pad " between the downpipe and exhaust manifold. :-\  Is this correct  or should there be NO gasket seal as before.
Webby the Bear
Did my first oil and filter change today. Absolute piece of piss :)
Got to say though it was the first time I'd been under the car with it on ramps and stands. Don't like it  :-[ I mean don't get me wrong I took all precautions..... up on ramps, chocls, axel stands in place in case it fell, jack stand in place in case it fell and one wheel under each side but christ i hated it. Thank God at College I know they have hydraulic lifts!
RIP Paul Lovejoy
Elite_L0ver
Quote from: amba on 08 April 2012, 17:39:59
9x out of 10 it will have a gasket as its a pattern part but make sure you got some exhaust paste as well you may need it  :y
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Elite_L0ver
Quote from: Webby the Bear on 08 April 2012, 20:40:24
For an omega baron WOW first one be safer than sorry or Ott
Webby the Bear
Quote from: 0mega_L0ver on 08 April 2012, 21:26:59
Yep, appearances can be deceptive  ;D
To be honest it's the only thing I've put off knowing I had to get under the car but it has to be done so I got down and dirty.  :y
RIP Paul Lovejoy
Elite_L0ver
Quote from: Webby the Bear on 08 April 2012, 21:31:20
Yep lol ;D :y
I like gettin down and dirty espically if it cones to the mig  ;D :y
Webby the Bear
[/quote]
Yep, me too. just didn't like having a 2 tonne mig straddling my head and genitals  :-[
RIP Paul Lovejoy
amba
All joints down side of cat have been sealed up with paste before assembly and securing with clamps. :y
No gasket was present when  I removed downpipe from manifold :o ,but reading online it seems that some models have a gasket and kit came with a "brillo pad " metal thing that I have fitted although it did make the nuts not go as far up the manifold studs as those that I took off  :o.Must say it looks a slightly  " Heath Robinson " affair the French have dreamt up ;D but I suppose as long as it seals thats the important thing and will then be hiden by manifold heat sheild  :y .Just wanted to ask if that seemed correct..Engine E7J 1390cc ;)
Elite_L0ver
Quote from: 0mega_L0ver on 08 April 2012, 22:45:37
Yep lol ;D :y
[/quote]
Its fine as long as your secure and not balancing on a jack alone I trust both my ramps jack and axle stands I can work under for long periods pull push and still be safe iv had a senic on em too and trannie and never felt safer IV a set of ramps if you want them
