Elite_L0ver
IV fitted new bonnet struts and spray painted rear drivers side bumper :y managed to get double sided tape stuck to my car  :-\ any ideas to get it off :'(
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
jonny2112
Fitted new control unit to sunroof - goodbye phantom ?  :-X
A wee taste of tar remover may help remove the sticky tape ?
Davidhughes
Cleaned inside and out, bit of a chore and wouldnt mind paying somebody to do it!
Temporarily fitted new front arms. They're shit and the bushes don't line up >:( but as long as they last until I've renewed the old bushes then all well and good :-\ Car drives ok so set up last week wasn't a total waste of money.
Also disconnected the knock sensors again as having to restart the car at every set of lights was starting to irritate me no end ::)
Oil and filter on the DTi and removed the leaves from the scuttle drain.
The Red Baron
Quote from: Davidhughes on 19 April 2012, 20:31:13
have a word with Dan282, im sure he would help. :y
Quote from: The Red Baron on 21 April 2012, 18:23:53
Yep, he does a really good job and very reasonably priced as well :y
carls9941
Quote from: Loo-knee on 28 April 2011, 21:20:22
Doesn't matter if you have worked on an Omega or another one of your cars which isn't an Omega, just share what you have been doing  :y
finished fitting front coilovers today
doz
I got to crank the VW to build oil pressure prior to start. Then the heavens opened  :( So I still haven't finished it.
Murph
Front disks and pads replaced, new sensors on order.
doz
Just did a early morning dash down to Cornwall. First time I've stretched the legs on the Barge and to say I'm well happy. Didn't miss a beat even though the weather was howling down and I filled back up when I got here and worked out I'd got 31MPG. That was by being sensible but still cruising at 75 MPH where possible. Even got through the Black Down Hills without issue.  :)
henryd
Quote from: doz on 23 April 2012, 14:02:54
I hope you had a passport to come down here ??? ;D ;D
other rides
doz
Apparently I only have to show it when I'm crossing the border home  :P :P
henryd
Quote from: doz on 23 April 2012, 14:27:24
lol ;D ;D
other rides
flyer 0712
fitted a new starter motor today,,sunny at first then heavens opened up...me out in the open underneath the car and got soaked..but hey after a struggle got it done... :y
