geoffr70
Oh yeah, for some reason when the car was in the air, some new fluid put back in the sump, when trying to put it In drive to circulate fluid, it wouldn't come out of park. It did eventually though. Something to do with low fluid level possibly?
TC and BnQ Trade holder.
Driving around with imaginary air con on  ::)
Lay on my back replacing the front drop links on the MR2 this morning - so glad it finally stopped raining and the sun came out, and I only had to use Gerald the Grinder once.
Drove the Omega to Essex to drop off the T56+bell housing, drove back.
Took the MR2 for it's MOT which it passed (thank break, since the last one expired on the 26th  :-[ ), hurrah. Handing is also much less wayward now.. probably because I actually tightened the front wheel nuts up properly (note to self: always check when someone else has put the wheels back on the car...)
Quote from: aaronjb on 30 April 2012, 18:28:58
Ah, you know Mr Gixer as well then ;D
Quote from: TheBoy on 30 April 2012, 18:51:07
that's the last time I leave what I'm doing to help fat fingers on the other side of the car because he cant do it. Bloody stitch up merchant, do it yourself next time.  :P  ;D
JesperKjeldsen
drove it, and the familily  to the zoo and back 130km. on the way I came to think about how i could live without AC, quikly came to the conclution that i canĀ“t so I switched it on. ahhhhhhh
todays weather 22degrees and no wind..
Kjeldsen Out.
Quote from: chrisgixer on 30 April 2012, 21:45:26
Oh, you two love birds.. ;D
Today I emptied out the bathtub MR2 - rear drains were blocked so after all the rain we've had it was slowly filling the rear storage areas with water. Side vents off, drain ends off, find the other end through the water, flush through all the fetid leaves & vegetation and put it all back together.
Guinney1971
not doing owt to the Omega today, but I've got my DeLorean's battery on charge, then later I'm gonna check the fluid levels, tyre pressures, and then get the analyser out and check her emissions, tune up if necessary, then give her a once over before the dreaded MOT tomorrow - its actually stopped raining here and the sun is out.......
Claire
Claire & Phill
Renault Grand Scenic 'Maxim' 1.9dCi 120
Sam Burton
Im awaiting my HID Headlights to be dropped off (via Dad not courier otherwise snappy snappy to adjusters) and now moving onto pulling the headliner down to fit Illuminated Sun Visors :y
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
markrnorton
Well, not today, but yesterday.
Had a key cut and coded for my run about (the 2.2). cant stand having no spare
And continued stripping the engine ancilleries of the 2.5, as i want to get the engine out on saturday.
Never seen so many electrical connections, its a nightmare tagging them all !
Quote from: markrnorton on 02 May 2012, 11:28:09
Just disconnect the loom at the ECU, and one of the big connectors behind the battery and leave the loom on the engine. :y
markrnorton
Quote from: Kevin Wood on 02 May 2012, 11:38:02
I wish i'd known that last week
thanks though
it all has to come off as it will be fitted to my kit car
Last Saturday...
Got embarrassed by a RR Evoque around a roundabout  :-[
Fitted new cruise stalk.
Guinney1971
just been to Derby, where the DeLorean passed her MOT  :D, then went to DVLA Nottingham and got a nice new tax disc for it.
Happy days!   :D
Claire & Phill
Quote from: TheBoy on 02 May 2012, 19:21:24
Last Saturday...
Please tell me it was because you were driving it.  ;)
