Drove it, and noticed it was going exceptionally well.  :-\. Probably means its about due to seize ;D
Topped up the oil after the oil warning came on  :-[
Quote from: chrisgixer on 25 April 2012, 23:30:01
Wasn`t going that well then Chris :D
Quote from: RobG on 25 April 2012, 23:32:02
Oh it's egging me on at the moment.
Oil level about 1 third showing on the dipper. ;)
well i should 'av known better shouldnt I..... rear blind clicking like a bastward.   :'(
geoffr70
Changed the oil, cleaned the breathers, ICV, EGR, plenum and throttle body on my bros elite
TC and BnQ Trade holder.
The Red Baron
both heads off the 3.0l lpg elite, big failure on pass side bank rear. :o
tbh both head gaskets where on the way out, seems odd as the engines only done 80k, but then again it is a 98 engine. :(
not a job i want to be doing everyday tbh.
Drove it, looked at it and thought it needs a clean and realised that I need to get the stone chip fixed ASAP. Also thought I should do an Oil and filter change soon ::)
Quote from: chrisgixer on 26 April 2012, 19:39:18
You're on your own for that "20 minute job" ;D
Quote from: TheBoy on 26 April 2012, 21:00:26
i rekon i'll be in the dealers 20mins buying a new one. Bugger that  ;)
Quote from: chrisgixer on 26 April 2012, 22:29:03
Turns out they aren't that expensive IIRC?
Wonder why your (presumably motor) keeps failing?  That said, I can't vouch for that old one, it was 2nd hand when I got it, had it in the MV6 for about 3yrs before the annoyance with the faulty gearbox (rasping when closing) eventually got the better of me.  And I use it a lot. It really annoys people following ::)
Quote from: TheBoy on 27 April 2012, 09:29:26
I noticed yesterday, after coincidentally leaving it up all night, that it clicked after retracting. It went up fine, went down fine, just clicked about a second after it re seated.
A couple of uses with just a click, it then clicked constantly for about 2 seconds until mechanical sympathy maid me put it back up again, and the click stopped. It's stayed up since.
This one came from the Chav, and it was failed when I got it.
Wasn't that the one we changed the motor in last year? ;)
Is it a relay click, or a rasping noise?
Yep. It's mechanical. Rasping. Clickclickclickclick.
Guinney1971
'Morticia' is at RGS Motors in Langley Mill, she's having an engine service, front anti roll bar link and they're also gonna investigate why I'm getting so much tyre noise from my new (partworn) OSF tyre.
Unfortunately they've confirmed the main oil seal has gone, which explains the drips of oil I've seen from under where the gearbox meets the engine  :(
More bloody expense.............   ::)
Claire & Phill
Renault Grand Scenic 'Maxim' 1.9dCi 120
