Lampynoiseboy
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
Quote from: Lampynoiseboy on 25 August 2012, 18:00:09
Swapped mig for an Insignia CDTI SRI as it's gone for insurance repair. Seat's uncomfortable, turbo lags & a lesser spec'd model but otherwise ok.
Although having put £85 of diesel in it, told by computer it has 645m of range, and having driven it to chelmsford, stafford, surrey, york, surrey & home discovered it was telling the truth, I wonder why in hell I'm driving a 3.2 v6 in the first place!
Are there any other diesel migs other than the 2.2?
Hmmmm. :-X :D ;D
If you go for a 2.5TD, for the love of god, make sure its a manual. Autos are not suited to engine, and return poor mpg.
Then chip it.
Lampynoiseboy
Unless I finally get the db7gt, or the 328gts I want, I don't think I could go back to manual, all my driving is flat out or break all, see no point in a clutch for every day driving
Is it that bad?
My old 2.5TD Auto Elite returned high 20s mpg on standard map, and low 30s mpg chipped.
Lampynoiseboy
Quote from: Lampynoiseboy on 25 August 2012, 19:23:22
What does a manual do?
Omegatoy reckons mid 40s, but he is like Miss Daisy :P ;D
twiglet
On the other side of the channel, you can get on Opel Omega with a 2.5dti lump and 5-speed autobox.  Probably the best drivetrain available for performance and economy, but the steering wheel will be on the wrong side!  :-\
If someone imported one and put the drivetrain in a UK spec car they would have a very sellable car I would think.
There you go Twigs - your next venture sorted for ya. :y :D
twiglet
Quote from: Albitz on 25 August 2012, 21:28:56
Maybe I should rip the 3.2 out of mine and stick one in!  :y
Lampynoiseboy
I don't really care what side the wheel is on, as long as there's one at each corner!
Fitted some mid sections to a members exhaust keeping the irmscher back box.
Took hours to seperate the rusted sections and remove. Hours!
Quote from: chrisgixer on 27 August 2012, 08:36:37
Oi  >:( rust holds some of our cars together  ;D :y
Quote from: EMD on 27 August 2012, 09:04:18
You don't know how true that is. ;D
adey2
just finished stripping rear hub after the retaining spring and clip failed in slough yesterday for handbrake, car sang a horrible grinding noise all way home as pin was rubbing hub all way, lot of work for such a small part
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
