Quote from: Mart280 on 03 September 2012, 15:41:52
I fitted a new battery today but there isnt a strap or clamp or anything to hold it in place, what do I need to fix it in position ?
Should be a small metal plate with a hole in the centre which bolts to the battery tray at an angle and hold the battery in position.
If its missing put a wanted ad in the test zone andadmins will move it to the right section for you.
Someone is bound to have a spare one they could let you have.If not,I should have one by this time next week. :y
twiglet
Quote from: twiglet on 02 September 2012, 20:46:48
Bought another one. Collect it on Wednesday.  :y
Successfully delivered 230 litres of veg oil deepest Essex, then headed over to near Stansted airport to collect the latest edition to the Twiglet stable...
I've already started to bond with the old girl, so I expect she'll be staying around for a while...  :y
How many black omega estates does one man really need ?  ::) :P
twiglet
Quote from: Albitz on 05 September 2012, 20:45:28
At least 2, maybe more... watch this space!!  ;D
They do say that three is the magic number. ::) ;D
Washed and MOT'd the Omega.. three advisories; one to say it has plastic sill covers fitted, one to say the exhaust is looking a wee bit threadbare and one to say that the offside front step sill is corroded..
So out of that lot, only really one thing I need to sort out - pull the plastic sill off, see how bad the rust is, grind it out and treat it (and/or weld up the resulting hole!). It's right in the front bottom corner of the drivers door sill..
Still any pass is a good pass!
FINALLY fitted the set of elite estate boot cubbyholes to my car, only had em for 6 years  ;D
Now after another set, anyone?
Quote from: Jimbob on 06 September 2012, 16:30:59
As is a mate of mine, I wasn't sure if they were retrofittable easily though - is it just a case of cutting a few holes in the carpet and clipping them on, by any chance?
Drove the DTi to Anglesey and back and laughed all the way as it sipped diesel :) :)
Quote from: aaronjb on 06 September 2012, 16:45:12
2 bolts one side, 3 the other...
there are dimples on the 'other' side for some, some you do my placement and drill.
bolt through from the rear, so ones by boot door easy via cubbyholes, other end, you remove trim and seat anchor (2 bolts) and you can get in.
Thanks Jimbob, good to know - I'll tell him they're alright to fit, then. And then he can spend his time trying to find a set.. ;D
Ive replaced my wiper motor, and fitted insignia washer jets while the scuttle was off, just got to adjust them now, bit low.
Quote from: Jimbob on 07 September 2012, 18:19:21
Think thats the nature of them, not adjustable?
there are tools to adjust them, they do move apparently.
pauls
Replaced seat bolt (thanks to yar244) also changed over doorcards to the new light greys ones to match my seats.  :y :y
