symes
finished setting my double pumper carb on my classic and fitted new sunroof switch light bulb on the mig
Quote from: Kevin Wood on 18 September 2012, 23:50:58
Left it at home and cycled 15 miles to have a pint with my mates instead. Knackered. No moon tonight. I need a  brighter light on the bike. Nearly missed a couple of bends on the way home. ::)
;D
Fitted a pair of Pedders Monaro rear subframe poly bushes 8) Courtesy of Messrs Monkfish :y
Shall report back once I've driven it in anger, but first impressions are promising  :y
Replaced both front ball joints, only 3 rivets and 4 bolts, piece of pish.... not ;D still only managed to break 2drill bits, one centre punch and bend a reasonably sized drift >:(
Swapped the outer track rods and drop links whilst there :y  all ticketyboo except for being unable to set up the front end due to a seized adjuster, would appear to be welded to the os inner trackrod end ::)
Rear end now feels like it's actually attached to the car again, nice and taught 8)
JimE
replaced the Steering Idler Arm, surprised at the difference it made!.
Quote from: taxi al on 21 September 2012, 18:52:06
I found it quite easy, although I did break the DRILL (not bit). Gutted.
My drill takes few prisoners, mains powered Bosch... didn't try it on the hammer setting :-\ might have helped shake the rivets loose, trusty Dremel saved the day :).
Next time I might just take the arms off and be done with it ::)
Quote from: taxi al on 22 September 2012, 10:49:25
Mine was my trusty old, indestructable Wolf, that was a present from my old boss ::)
The chuck and most of the gearbox stayed on wishbone, motor and housing came off in my hand ::)
 :'( 'Oh cock' springs to mind... was quite pleased with myself, managed to get one of the drill bits to shatter into 4 ::)
Manual Elite V6
Today I had new tyres fitted to the front of the Omega, I then replace the rear shoes and cylinders and adjusted them up on my mates Puma, also treated it to a brake fluid change for him.
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
BazaJT
Well,after finishing work I hoovered the Jag,then cleaned interior plastics etc.and polished inside of windows.Returned home and removed power sounder from Omega.
ozzycat
long live the magic tree
its good to be back
hotel21
Sat on my arse drinking the red wine that went with an extended rustic lunch of local bread and cheese whilst looking at the mig against a fine seaside backdrop.
Must change the oil and filters sometime soon......
