Nothing, the dreaded Manflu has set in :(
Jacked it up with the intention of finding a slight creak, layed under it just looking, fiddled with this and that, layed there looking at it, pondered the realitys of routing v8 manifolds out of the engine bay, layed there some more, and  looked at the slightly leaking sump, layed there some more, nice and warm it was as I'd just been out in it, next doors cat came along and sat next to me. ...then remembered the oil is due, so changed that instead.
Presume the polys need greasing, bugger it, can't be arsed, it will become clear what the problem is sooner or later. Now drinking the last beer out the fridge. :)
Quote from: chrisgixer on 28 September 2012, 18:43:58
;D They always do that they can sense frustration  ;D ;)
Think that may be creak on Silver Bullet (although I have acreak from back now, since messing with that bush
My fridge was looking bare a few days ago, but since then, 2 crates of Stella, 2 boxes of Stella Cidre and 8 bottles of Cobra have turned up for various deeds performed...
idle sometimes become so bad that car nearly stops..  probably idle valve donald.. and recently cleaned it..
wishbones needs changing again and cambelt approaching.. road computer pixels dead again..
small one needs new shocks..  >:(
Quote from: TheBoy on 28 September 2012, 21:27:44
sounds like you need a hand with that lot.. ?  ::)
Another two tyres on Mrs VXL V6's Estate, In two months that's eight tyres i've bought across the fleet!  :'(
Removed the front and rear bushes from a pair of new Lemforder arms and a set of Polly's are sitting in the boot of the V6 ready to fit.
Webby the Bear
After martin mended my fuel line was loving the car again..... until the door decided not to shut 10 mins before i went to the saints  >:( >:( >:( >:(
got it shut after ten mins of cursing but got to sort that today.
plus also reclip and cable tie my breather pipes to cross that off the ''things that could be affecting my fuel use'' list  ::)
RIP Paul Lovejoy
Quote from: VXL V6 on 29 September 2012, 10:04:23
I'm sat watching 4 go on, that's going to upset the bank manager :(
Quote from: TheBoy on 29 September 2012, 10:23:58
Remember to thrash the living daylights out of it drive carefully for the first few miles until the releasing compound wears off
Swapped my crappy old key fob buttons for the nice shiny new ones that arrived today 8)
Decided to refit my power sounder following battery replacement. rather thing had gone off before I'd even put the scuttle back on, so that idea has been permanently consigned to the bin. >:(
Quote from: Kevin Wood on 29 September 2012, 20:04:29
Did you turn it off with a universal key  ::)
No, I don't think it was actually the power sounder's fault, but the hopeless connector that it plugs into. Appears to have gone rotten inside despite being cable tied into a plastic bag since the power sounder had a hissy fit.
Perhaps a dose of WD40 in the bag first, just in case there's any moisture in the air :-\
