Quote from: Stallion on 06 October 2012, 02:33:23
Realised been a year since i last saw Daz had my cambelt/service done, so decided to clean out the breather and throttle body, was surprised at the amount of shit gunk that come out from it although didnt cover much mileage >3000 maybe?  :y
Short journeys will make it worse
Stallion
Quote from: TheBoy on 06 October 2012, 08:54:50
Explains it why? as mines been full of short journeys. Im guessing il be cleaning the breathers every 6mths then, Thanks TB
Picked up my tapped inlet manifold, cheers Kevin :y and forgot the clutch was slipping whilst doing a wet weather budget tyre test ::) lsd still works though 8) tyres also proved themselves 8)
Today I be mostly starting on lpg electrical loom.
biggriffin
just changed the door solinoid and it still dont blo*dy work,have to take the one off shed 3 see if that works otherwise it electrikery problem,will do it next week.
Hoof'land storeman.
Replaced the perished sections of rubber pipe in the vacuum pipework to the multirams - they now work properly again.
Oh, and currently trying to do an SMG relearn on the M3, only that bit isn't playing ball..
Washed it and now it looks worse than when i started ...dam rusty doors  ::) :-[ :-[ :-[ :-\
Took the Kwaka for an MOT.
Now need to decide whether to fix it, or scrap it.
I'm tempted by latter, but suspect I'll never ride another bike  :'(
Fixed the alternator. Bearings in the 2nd hand one had dried out a bit on the shelf, so swapped the regulator out of that into my old one. Will refurb the other as a spare.
Thought about washing it then thought no.. "when you've learnt to behave". >:(
Planned the routing for the Lpg loom, not 100% certain on where the ecu will go, certainly osf corner, but I didn't pull the bumper off, so undecided whether I'll need to remove the compressor to feed the plug through  :-\ Bumper will be coming off anyway :-X so will have a good look then :y
I've extended the piggyback loom and added the large plugs to simplify that, and have extended the loom to the engine ecu and fitted a plug to the reducer temp sensor. :y
Tomorrow I be making brackets for the injector rails...
Quote from: ex taxi al on 07 October 2012, 02:08:55
There is a hole in the in the metal work for existing wiring to run through under the air box,  that the quite large loom plug will fit through. I didn't remove the bumper on mine, jack car up, feed loom through, attach ecu to plug, bolt ecu to wheel arch liner. (or make brackets to bolt onto the sl compresor mounts, this does need bumper off though) Done.
Quote from: TheBoy on 06 October 2012, 20:15:35
What did it fail on?
Quote from: tunnie on 07 October 2012, 08:40:35
Not much they can fail on  :-\
