joff
Quote from: RobG on 29 July 2014, 19:50:59
Quote from: joff on 29 July 2014, 18:48:32
Removed the engine, gearbox, rear axle and prop shaft from the MV6. Sits a tad higher than normal ;D ;D :o. I think another day on this one should have all the parts off and then it's away with it.  :-[
Where did you find that then Jon ::)
Sorry Rob (diff) :-[ it's been a long day :y
Lost a screw and found a bulb behind the dash , need to wire the radio in at some point so it stays on without the ignition on ::)
4x4
Replaced 12s socket,also replaced mounting plate with a couple of modifications,and all good ready to get a tintent :)
joff
Taxed two of them (£570) :'( driven two of them and looked at the other two :y
flyer 0712
applied waxoyl to all of the under neath of my omega..hot day...waxoyl getting thinner...and more on me than the car but well worth doing and no more for the next 12 months .. :y :y  ;D ;D
joff
ffcgary1
Aircon was vac'd and gassed today FOC  :y washed and leathered down and hovered out. :y
sent my new tailgate and front bumper painted plastic to the bodyshop to be painted, Z359, spent a couple of hours just driving it and loving every minute of it as well.
Gary
Jaguar XJ6
Had to buy a new fire extinguisher today...
4x4
Aircon........
Need to get new pipe,as hole is in pipe between condensor rad and dryer,looks like a vx design fault,or some idiot has tighten nut on rad and allowed pipe to be against chassis allowing it to rub causing hole.
henryd
Quote from: Taxi Al on 02 August 2014, 14:17:18
Can't  believe you wasted it on a Ford  :-X
other rides
Quote from: henryd on 02 August 2014, 15:31:35
Seemed like the decent thing to do :y
Overtook a blue frontera coming back from serek's  ;D ;D ;D :P
X30XE
Replaced a steering idler arm. New one seems to have too much play in it as well   ???
Time to have a cup of tea to calm down before the inevitable disappointment of the test drive.  :(
Oh, and whoever invented automotive ball joints should have a place in hell reserved  >:(
Omegatitis : [in remission]
