Lagondanet
Been to Luton & back then Warwick & back.   :y
driver115
Eldest daughter has for the first time today been driving the micra runabout I purchased for her.Took her out with me to begin with, shes now gone off for the afternoon with it / boyfreind in toe, and all going well today she will drive it tomorrow from N Lincs to Plymouth.Jobs I`ve done on the micra since getting it last month include : dealt with some rust spots,new drive belts x 2, sparkplugs, fuel filter, new tyres,wipers,engine oil and filter , gear oil, replaced brake fluid/brakes/disks checked as fine together with coolant - roadside check this morning on some of these jobs before we took it for her first drive
As a concerned parent may well follow them back down to Plymouth ie 3 car convoy.Its a "noddy car" but by all accounts in tip top condition, but not a motorway car more a city runabout
Steve B
Quote from: driver115 on 18 April 2015, 17:13:33
Is that the one with the hidden bolt on powered steering pump.
The Sheriff
Quote from: EMD on 18 April 2015, 13:24:41
Drained the pond out ,the area under the pollen filter  ::) Changed the pollen filter . Tried to polish the headlights "failed"  :( Fixed the loose battery  ::) Found a used crank sensor in the boot  ::)
Put it on eBay, some wazoo I will buy it. Tell them it's goosed, totally useless, it won't matter.
Quote from: EMD on 18 April 2015, 13:24:41Tried to polish the headlights "failed"  :(
Try using the Headlight refurbish 3M kit that you use with a variable speed drill, the results are usually pretty good on headlight lenses that have gone yellow.
Steve B
Quote from: VXL V6 on 18 April 2015, 19:01:46
Are all omega light lenses plastic  :-\
Mr.OmegaMan
Quick question no point making a tread about it...
Just to confirm is it 5.75L of Oil for a 3.2 V6 ?
chrisgixer
Quote from: Mr.OmegaMan on 18 April 2015, 20:22:31
With oil and filter, I usually lob 5.5ltrs in and see where the level is after a warm up.
Mr.OmegaMan
Quote from: chrisgixer on 18 April 2015, 20:34:11
Quote from: BIGtime on 18 April 2015, 19:22:15
All apart from the very early models.
Shackeng
Finished greasing the brake pipes and ferrules for Thursdays MOT on the Elite. I'll give it some cat cleaner and an Eytie tune-up before she goes in. ::) :y
Topped oil up on 3.2 on Friday, gave it a bit of a clean. As it would be fully loaded, taking work mates to Go Ape  :)
EMD
Trying to get any result from a product by hand will tale ages  :( I think it needs some wet an dry over it though then polished with the kit you mention  :( There not badly hazed , just starting to fade at the top but would like to get them done  :y
Omegatitis
4x4
Got fed up with the truck looking in a sorry state,so gave her a hand wash,then went to jet wash for another wash and rinse down,then back home,dried her down,then set to work removing scratches from where i had been off roading,now looks shinny and clean again.
Took the hard top off the M3 yesterday, gave it a wash and a few checks and then spent a very enjoyable 6 hours or so blasting around the Brecon Beacons with a couple of friends in their cars.
Today took it to the Morgan factory and had a ride out in a Plus 8 Speedster which literally took my breath away at speed. Although the driver was a rather tall, slim, attractive blonde which may have had something to do with it. Factory tour etc. it's an infectious place and now I really wish I had £90k to buy one..
