You want Sikaflex 221 or 255, not that stuff which is designed for fitting windows to houses.
That or Tigerseal or Wurth Bond & Seal
And grey is soo '80s ;D so be sure to get black :y
EMD
Looks like the devils bay again for the Sikaflex 221  :y
Omegatitis
Quote from: aaronjb on 17 April 2015, 22:05:53
That is what I bought it for. Nice to know that I bought the right stuff :)
Quote from: Andy H on 17 April 2015, 22:31:07
;D lucky, that. Of course if EMD sticks a spoiler on with it he might end up retrieving said spoiler from a live lane on a motorway ;)  ;D
EMD
Quote from: aaronjb on 17 April 2015, 22:35:12
Also i need it to stick so light fingered types dont rip it off  :(
Omegatitis
With the three I mentioned and properly cleaned surfaces it won't be coming off without chunks of bodywork attached..  ;D
Quote from: aaronjb on 17 April 2015, 23:05:05
Certainly the one I use is good to 150+ ;)
Terbs
Today I have removed both front door cards, and screwed the plastic retainingg strips to the door card, using small chipboard screws.
Had to do this on all three cars now, but at least the cards are now solid at the top and those confounded locking knob rattles are gone. Got it off to a fine art now :y
steve6367
Finished the condensor on the 2.5, dropped one of the copper washers for transmission cooler and had to pay £7 for a set in Halfords so I could finish it! Grrrr
Sat in ATS watching the refrigerant go in, so hopefully that part of the job is gas tight!
Steve B
Quote from: steve6367 on 18 April 2015, 12:42:38
How many pennies do they want  :-\  formula 1 were £25 a few weeks ago.. had mine done there.
Fitted my new bonnet struts, as I can't be arsed to change the strut bearings.
At least the bonnet stays up now.
I'm probably going to make an adapter to try my oil pressure gauge on the Omega next.
Although I might get a call to help with a Capri gearbox, which will be worth a couple of beers.
EMD
Drained the pond out ,the area under the pollen filter  ::) Changed the pollen filter . Tried to polish the headlights "failed"  :( Fixed the loose battery  ::) Found a used crank sensor in the boot  ::)
Omegatitis
steve6367
Quote from: BIGtime on 18 April 2015, 12:56:33
I had a hunt around, but seem to have missed the winter offers - £45 here. Not sure I checked F1 though  :-\
minifreek
Re-fitted the lowered suspension with spring assisters on the rears to help when the caravan is on... won't bottom out quite as much now :)
Ready for the summer season now, just need to wait for a cool day to give it a wash - clay bar - wash and polish :)
D.I.L.L.I.G.A.F...
