Quote from: Webby the Bear on 30 April 2015, 17:47:47
Fluid top up on the omega. Pas, coolant  ::) and washer fluid. . . . Something really satisfying about topping up washer fluid. No idea why  :-\
It's the bubbles Webby... The bubbles ;D
Taxi_Driver
Quote from: STMO on 30 April 2015, 19:32:05
I use the Hungarians at the top of the road. They charge a fiver but they do such a good job I give them £7. Hard working lads.
So that's an extra 2 squid to the boss then....don't believe for one second he passes that on to the workers.....
Obviously, don't know how much they paid in your area Steve, but in Swindon, on average the workers get £40/day for maybe 10 hours a day.....the boss takes the rest.....but obviously has expenses to pay....
The Sheriff
Quote from: Taxi Driver on 30 April 2015, 19:45:12
The tips go in a plastic container labelled...erm.....tips ;D  Not sure who gets it. If it's the boss, so be it, but they are very grateful.
Shackeng
Quote from: Taxi Driver on 30 April 2015, 19:24:03
I got mine cleaned inside and out for a fiver  :y Taxi driver discount  ;D :)
Tho they've gone a bit tight recently and don't give me a dangly rear view mirror thingy  :(
Is that Tesco's TD?
minifreek
Decided to tax it for 12 months ......
Had a ruddy close look at what needs doing to sort out the O/S rear arch, so I'll be cutting and grinding and welding and filling and primering and painting and lacquering this weekend.....
Also found a hole in the floor.... :( so gonna patch that up at the same time I reckon...
Also .... need to rehang the O/S exhaust as I went over a large speedbump and kinda clattered the damn thing so broke a hanger I think.... I did mean to hang it higher than it is, but never did it last week....
D.I.L.L.I.G.A.F...
Webby the Bear
Quote from: Taxi Al on 30 April 2015, 19:36:10
Ah yes, Ive just realised you're right  ;D
RIP Paul Lovejoy
EMD
Oil pressure switch
2nd oil and filter change
Lifter treatment
Omegatitis
Steve B
Quote from: EMD on 01 May 2015, 18:18:11
Oil pressure switch
Lifter treatment
Why you done a few oil changes Emd & Do you have a lazy lifter on startup
EMD
Quote from: BIGtime on 01 May 2015, 18:22:14
Oil pressure switch
Lifter treatment
Slight lifter tap "cold start" since its first oil change in my ownership . Bloody oil was filthy  >:( Lot better now though with the Wynns lifter treatment .
Omegatitis
Steve B
Quote from: EMD on 01 May 2015, 18:30:05
Oil pressure switch
Lifter treatment
got that too.. but once warmed up..Gone
EMD
Quote from: BIGtime on 01 May 2015, 18:36:00
Oil pressure switch
Lifter treatment
The first oil change i did , the oil looked like it had been in there since it left the factory  ::) The filter was distorted/brittle and of course black , shocked any oil went round the system  :(
Did an engine flush but cant start it up as waiting for an oil delivery  ;D
Omegatitis
MV6Gaz
Removed power sounder (board was black inside) and fixed a broken connection, wash and hoover :)
05 Volvo S80 D5, 98 V70 TDI, 99 V70 SE
Delroy47
Changed nearside rear door and hoovered the interior  :)
Fixed a broken wire in the Galaxy's driver's door and now the central locking works :y
Tried to start it and found that the battery was flat :(
Quote from: Andy H on 02 May 2015, 16:41:41
Same door looms as Alhambra then!
