Author Topic: So what have you done to your car today?  (Read 5674163 times)
0 Members and 20 Guests are viewing this topic.
« Reply #12195 on: 16 March 2016, 19:15:55 »
Managed to get 72.5 litres of motion lotion into it:-X
High octane I hope.  ::)
Triple points 8)
pauls
  • By the sea minehead
    • Bmw x3
« Reply #12196 on: 16 March 2016, 21:34:26 »
Painted rear calipers and just received my pontiac front calipers from the states, just have to arrange fitting now :y
« Reply #12197 on: 17 March 2016, 09:05:20 »
One down, one to go...
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #12198 on: 17 March 2016, 16:52:26 »
Estate failed the MoT today as the washers for the headlights did not work ( didn't work last year but it passed) now fitted another pump from the parts shed which works and rebooked for Saturday afternoon.still has under 100K on it just. :y
tidla
  • solihull
« Reply #12199 on: 17 March 2016, 17:42:08 »
How can they test that then when they only operate now and again?
« Reply #12200 on: 17 March 2016, 17:46:56 »
What?
    • 530D M Sport, 330i Coupe
« Reply #12201 on: 17 March 2016, 17:56:56 »
On HID equipped cars they should work whenever the headlights are turned on. Part of the regulations I believe.
« Reply #12202 on: 17 March 2016, 18:07:54 »
That's what I thought.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #12203 on: 17 March 2016, 18:22:52 »
I believe they work that way on all Omegas with headlight washers and did so on the Senator too.
EMD
  • Noofhampton
    • 95t
« Reply #12204 on: 17 March 2016, 21:58:18 »
Ripped the standard ugly radio out  :D What a bastid that cage holding it in is to get out  >:( Still a nice looking surround put in with a wee cubby hole for odss and ends underneath . Ready for the new bluetooth unit  :)
Omegatitis
« Reply #12205 on: 17 March 2016, 22:06:04 »
Just remove the retaining screen, squeeze the cage top and bottom and it'll come straight out.
EMD
  • Noofhampton
    • 95t
« Reply #12206 on: 17 March 2016, 22:20:52 »
It was jammed in , dont think it had ever been out before . Ended up taking the whole climate panel and surround out  :( Luckily i'd done that on another or would still be there now  ;D
Omegatitis
« Reply #12207 on: 17 March 2016, 23:09:26 »
Sometimes some of the tabs need to be bent inwards or the edge of the top square cutout's can occasionally catch.
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #12208 on: 19 March 2016, 15:55:17 »
New MoT on the Elite, just have to poly the rear and check the hand brake now.
Bikerdon
  • Glasgow
    • Vauxhall Omega 2.6 V6 Est
« Reply #12209 on: 19 March 2016, 16:02:20 »
New timing belt and associated pulleys fitted, aux belt tensioner repacked with grease too as it was a bit dry, the cambelt DVD is worth every penny for someone who has not tackled this job before, all back together and running sweetly, timing on both banks was off by a small amount when the cover came off but spot on now. also found a small split in the rubber elbow on one of the vacuum lines to the bagpipes, all repaired and noticeably perkier acceleration now.
Page created in 0.037 seconds with 21 queries.
