Author Topic: So what have you done to your car today?  (Read 5860416 times)
0 Members and 26 Guests are viewing this topic.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #27780 on: 02 July 2025, 20:01:11 »
How does cruise control affect the  life of the pads?
It shouldn't unless it's advanced cruise that also slows the car... In which case slowing the car from the rear makes for smoother braking from a passenger comfort perspective as it limits the nose dive effect………….
Well you could be right Al. I just googled VAG ACC rear pad wear and it appears that under very light braking it applies rear bias for the reason that you stated, and uses normal bias for heavier braking……. and pre-sense for those suicidal moments.  ::)  ;D
Maybe it’s just a VAG thing.  :-\  or maybe it’s total horse shite.  ;D
That's bloody dangerous, as the vehicle has no idea what the road conditions are and could easily spin you if you were on an icy patch
A further search reveals that Volvo’s do the same apparently.  :-\  Quoted from a Swedish forum :
‘ Volvo Adaptive Cruise and Pilot Assist is very brake happy instead of coasting to slow down, and uses primarily rear brakes.’
I don’t know for certain Mark, I’m only going on what the Indy told me and what I’ve read, so it’s not factual on my part and could be wrong information.  :-\
YZ250
« Reply #27781 on: 02 July 2025, 20:06:54 »
Speaking of VAGs, I dumped mine in the short stay, and now running around in a VAG shitbox.
I singlehandedly makes the Battlebus feel powerful and fast
Exactly, the ideal car for reformed characters like ourselves.  :y  It discourages the temptation to drive really fast.  :y ;D
What is this gutless wonder you’ve been loaned?  :-\
« Reply #27782 on: 02 July 2025, 20:09:40 »
A white one.  No idea what it is, and it's out of view.  But it is dangerously slow.
Optie will cream his jeans because it is petrol.
« Reply #27783 on: 02 July 2025, 20:10:58 »
Slow as in foot flat to the floor on a slight incline in 3rd, 50kph is all it would give....
« Reply #27784 on: 02 July 2025, 21:31:22 »
Sounds like the 3 pot 1.0 with cylinder deactivation  :D
Whomever came up with that nonsense in that package clearly wants a job at Audi design.
« Reply #27785 on: 02 July 2025, 22:25:51 »
Lord Opti doesn't wear jeans.  At his age, he prefers brown polyester trousers that belt around his belly button.  8)                                                             ;D
    • Grandland 1.6 diesel
« Reply #27786 on: 02 July 2025, 22:30:55 »
Lord Opti doesn't wear jeans.  At his age, he prefers brown polyester trousers with an elasticated waist 8)                                                             ;D
Fixed  :)
Diesel till I die
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #27787 on: 02 July 2025, 23:09:01 »
It shouldn't unless it's advanced cruise that also slows the car... In which case slowing the car from the rear makes for smoother braking from a passenger comfort perspective as it limits the nose dive effect.
That said I found the brake bias on my Altea to be heavily to the rear, so my first thought is that accelerated rear brake wear is either a VW thing or indicative of a fault.
Laying a rubber road.
Raeturbo
  • South Wales
« Reply #27788 on: 02 July 2025, 23:13:24 »
« Reply #27789 on: 06 July 2025, 16:54:54 »
Finally overcame CBA to look, the badge on the back says Skoda Fabia. So I assume it's also a VW Polo and Audi A2.
It's poorly put together, going by the rattles, and carries the spec of a 1959 Mini.  Only less powerful.
But it'll do for the week, and was reasonably cheap.
« Reply #27790 on: 06 July 2025, 18:46:36 »
1.0 12v turboish with cylinder deactivation then...
Aka utter nonsense.
« Reply #27791 on: 06 July 2025, 19:39:47 »
If it's 1.0l lightly blown, either the engine is shagged, or the car weighs about 3t
On the upside, it would appear to be staggeringly frugle on fuel
« Reply #27792 on: 07 July 2025, 17:25:34 »
Swapped the little shitbox for the day, for something with 650cc and significantly quicker ;D
« Reply #27793 on: 07 July 2025, 17:41:39 »
Swapped the little shitbox for the day, for something with 650cc, two wheels and significantly quicker ;D
Did I fix that right?  ???  :)
countrywoman
  • worcestershire
    • skoda yeti
« Reply #27794 on: 07 July 2025, 18:28:21 »
Got the Omega window mechanism working on The Austin, O what fun was had. Made 20x20 box into 20x8 with a slot up middle (as per the size of the adjustable bit) and welded a plate to it that bolts to the VW channel that fits to the glass. First side took 2 days but drivers side less than one day as I knew what to do/make. Getting very close to a road test now.
Page created in 0.017 seconds with 15 queries.
