minifreek
I dunno if my auto levellers actually work LOL
D.I.L.L.I.G.A.F...
chrisgixer
Quote from: minifreek on 04 May 2015, 10:47:27
No but I'm sure other drivers will notice if their not. I'm sure you hate being dazzled by poorly adjusted head lights same as the rest of us.
minifreek
I do, but it doesn't help that my Omega is lowered so I sit about 50mm lower than the rest.... and Im only 5'6 too....
D.I.L.L.I.G.A.F...
chrisgixer
I guess uneven tyre wear isn't a concern in that case.
But the level system will be working,unless you've get headlight field of vision flashing up on the display.
Mr Gav
I changed the goosed HBV and removed the power sounder while I had the scuttle off  :)
omegod
Finished stripping my mondeo tdci breaker, happy to see the receipt for a brand new DMF + clutch was correct ££ ;)
Also drained £25 worth of diesel out of it to go into my pug 306
pauls
Had my cid fitted and rear doughnuts today at the wycombe meet thanks to the boy and chrisgixer :y
humbucker
I stripped my MV6's engine, dismantled its cylinder heads, gave its manual gearbox a third layer of paint... The nuts and bolts are coming together nicely!
http://www.irmschermv6.com | #irmscherMV6
PM with your requests.
EMD
Omegatitis
Watched Chrisgixer fit rear polly donut bushes on my 3.2.  :) :y
Cheers Chris  :y
chrisgixer
2boxerdogs
Washed & polished my 2.6 &  also the wife's Fiat Panda both looking very smart now !!😀 😀😀
minifreek
Quote from: chrisgixer on 04 May 2015, 11:15:07
Don't get any uneven tyre wear at all mate, been set-up correctly you see ;)
And no the warning doesn't come up on the display :)
D.I.L.L.I.G.A.F...
chrisgixer
#10123
Quote from: minifreek on 05 May 2015, 08:12:47
Set up correctly? What's the rear camber at 50mm drop? It's either incorrect, running poly eccentric trailing arm bushes which are not for the omega, or something is amiss.
GastronomicKleptomaniac
Replaced rear multiram actuator and N/S coil pack. Took up the road for a test, and OS coil pack shat itself. Took it home, changed the starter motor in the pouring rain, bolted back together... And now the sun has come out. Grrrrrrrr.
