Quote from: YZ250 on 14 January 2016, 21:22:45
Quote from: biggriffin on 14 January 2016, 18:23:24
.......noticed a few times, back end was loose on corners, and bit of turn in oversteer,  Whoops tyre pressures all over the show :-X
Same here, mine is a rim leak on one wheel so without a refurb I'm buggered.  :'( It will stay at the same psi for a few days until the wheel rotation lands on the bad bit and it will drop to around 11psi overnight. I'll have to get it sorted as it's pissing me off keep inflating it.  >:(
I failed my walk-around checks this morning as it was down again and I felt it rather than see it.  ::)
Usually its the bead, a good tyre fitter would grind down the corroded area and apply sealant tot he rim before tyre fitting (some just lob the sealant on the corrosion and of course, it then leaks)
biggriffin
Quote from: Marks DTM Calib on 15 January 2016, 08:27:08
They are rare
Hoof'land storeman.
YZ250
Yeh sorry, that's what I meant, the bead seal to a flakey rim, but you are right in what you say as the rim needs dressing to cure this.  :y
Quote from: YZ250 on 15 January 2016, 10:14:24
I have the same, the fronts can easily loose 5 PSi over a week sometimes.  :(
I've got a set of new Kuhmo's on early F/L Elite Alloys, but I much prefer the later ones. I plan to go to WIM to get them to swap over the tyres and double check the corrosion on the rims. Also time it had a Geo-session as well.
Can't wait to get rid of the shite Nexen's  >:(
joff
Had to put a new expansion tank on the Elite today due to the float coming off its mount, also picked up some 5W30 from the dealers at only £12.50 plus vat for 5 ltrs, 20ltrs of antifreeze £20.99 and 5ltrs screen wash £2.50 each :y
plym ian
Had the rac out due to a flat battery and after swmbo bless her was pushing the omega down the road for me to try and bump it but it wasnt having any of it.
Mr rac said that my battery has just about had it and would i like a quote on a new one.
£110 for one is a bit steep i said so i'll get my own one to which he replied yes it is a bit but if your battery dies again we wont come out to jump it again. Which is fair enough I suppose
Any recommendations for brands of battery at all? 2.2 petrol btw
Quote from: tunnie on 15 January 2016, 12:07:02
They must be bad :o :o :o
Quote from: plym ian on 15 January 2016, 14:42:04
Halfords 063 Should do nicely for a sensible cost :y
Quote from: Lazydocker on 15 January 2016, 15:00:14
Ohh they are. Even me driving, when not even remotley trying they loose traction.  :o
ECP or CP4L often do good deals on batteries.  :y     Especially when they've got a sale on!  :-X  :D  ;D
flyer 0712
Took my desmond for an m.o.t. today..three weeks before it was due and it passed with fllying colours and the tester commented on it being a very sound motor......So this car that i bought nearly a year ago and spent a few quid on and i must admit did not have a great deal of faith in..has now made me a happy bunny and restored my confidence in these old barges..happy days once again... :y :y
I recently got a battery for the 3.2, for under £40 from eurocarparts :)
plym ian
Quote from: Sir Tigger on 15 January 2016, 18:12:26
Going to get one come payday as i found a promo code giving me another 10% off  :y
GastronomicKleptomaniac
Quote from: tunnie on 15 January 2016, 23:59:09
Likewise. Keep the guarantee paperwork and bob's your uncle.
biggriffin
Quote from: plym ian on 16 January 2016, 07:44:31
Going to get one come payday as i found a  ;D code giving me another 10% off  :y
ECP doing discount codes, wow there's a surprise
Hoof'land storeman.
