Quote from: Harris K Telemacher on 11 January 2016, 16:36:12
Stripped a pair of front struts for parts, measured springs in the process. Destroyed an alternator and vandalised the front multi ram. A good days work  :y
Sheesh.  :o  ;D
Quote from: Kevin Wood on 11 January 2016, 09:29:09
Changed the £$£^%$^%$ handbrake cable. >:(
Yes, a job I need to do, hopefully not this side of the MOT.  I wonder if Mr Gixer's warm garage is tidy yet. If not, I know of a very nice, warm garage a few miles from Alton :P
Quote from: STEMO on 11 January 2016, 16:47:15
Sheesh.  :o  ;D
Pmsl ;D
Put some air in some of the tyres, and took air out of the others. Drained the compressor whilst at it, been a bit lax doing that recently  :-[
Quote from: TheBoy on 11 January 2016, 17:28:27
And the owner has recently changed a handbrake cable so will be well experienced ;) ::)
Plus there's a magic cupboard there that seems to spew forth copious amounts of beer :y
GastronomicKleptomaniac
I didn't struggle too much with the Special's handbrake cable, which is surprising as I am a total moron with fists of ham...
steve6367
Changed the exterior temperature sensor - climate working properly and I am warm again  :y
The old sensor had decided it was 39.9C outside so all times!
Quote from: Lazydocker on 11 January 2016, 21:29:33
There's a nice comfy chair from which I can direct operations whilst performing a vital quality control function vis-a-vis said beer, too. :y
jimbo125
Valve spring compressor, any idea of collet size and throat dimensions. Seen some with 25 and 30mm collets and throat dimension of 140-160mm any good? :y
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
minifreek
Have discovered that the exhaust has decided it wants to start to blow....
Might be time to change to 2.6/3.2 headers :) :y
D.I.L.L.I.G.A.F...
Quote from: jimbo125 on 12 January 2016, 08:09:56
I found that one like this http://www.ebay.co.uk/itm/10-pcs-Car-Motorcycle-Valve-Spring-Compressor-Tool-Bit-Set-UK-SELLER-/261313098765?hash=item3cd779740d:g:RZcAAOSwPcVVhDCN  did a good job.
It's hard to argue with the price.
gbh
Well I went to look at a possible omega estate car but not convinced as of now!!!
Quote from: Kevin Wood on 11 January 2016, 23:29:48
Race you to the chair, and sod the handbrake
Changed the front disks and pads that I realised yesterday wouldn't be popular at my MOT tomorrow morning.
Went out and "tried to bed them in". :-X
There's a funny smell. ::)
They've about twelve hours to cool down ::)
