Repaired top strips on two rear door cards. Chemical metal seemed to work well on the front one so thought I'd use the same.
Rear bumper, rear wheel arch, both offside doors and front wing... >:(
Quote from: Harris K Telemacher on 03 January 2016, 17:54:27
That's a lot for one day's work.
Quote from: STEMO on 03 January 2016, 18:49:30
Not really... All it took was a ditherer joining a dual carriageway ahead of me, a panic braker on said dual carriageway and an overtaking Avensis in lane 2 of said dual carriageway.
To be fair, the Avensis did most of the work in about two seconds flat.
Shit. You'd better get cracking looking for doors and panels.
I knew, more or less, what had happened btw., but I was in no mood for teasing it out of you.
Quote from: STEMO on 03 January 2016, 19:21:05
If I am lucky, which I generally am not, the salvage company that a recently scrapped estate went to haven't processed it yet...
Head is still banging. No significant injuries though, so all in all could be worse...
Quote from: Harris K Telemacher on 03 January 2016, 19:29:54
Forgive me, Al, I am an unthinking t**t sometimes. Glad you are ok.  :-*
GastronomicKleptomaniac
Glad you're OK Al, good luck with the parts search!
Quote from: Jimbob on 02 January 2016, 17:21:09
Over the last few days I have watched Mark do an oil cooler on the omega and a cambelt kit on the zafira. Thanks very much Mark. Much appreciated :)
Quite enjoyed doing the oil cooler, it's good to know I can still remember the procedure
Struth... Glad all are ok.
Lagondanet
Back to work. Commute to London.
Happy New Year.
Did one of the lower wishbones on the front of the BMW over the break (or tension rod, in BMW parlance).  Would have been an easy 30 minute job including tea break if I hadn't had to grind the balljoint nut off.
Taxi Al single handedly trying to write off as many Omegas as possible ;D
Its only a bit of tin, as long as flesh and bone remain in tact :y
Quote from: Marks DTM Calib on 03 January 2016, 21:16:37
Good to know in case the Bullet decides to eat one :P, as its 17yrs old....   ....although I'm not sure if we did cooler as a matter of course the first time we did the head gaskets all those years ago? Can you remember?
Quote from: TheBoy on 04 January 2016, 17:02:27
Oi I resemble that remark :D
Very true. In that order.
Sadly my insurers have rolled over... So i won't be claiming, so it won't be written off... Which is nice.
Two doors, wing, an afternoons effort and a lick of paint and all will be well. And thanks to Nigel, panels already lined up 8)
