jimbo125
Quote from: Nick W on 12 January 2016, 18:19:47
Quote from: jimbo125 on 12 January 2016, 08:09:56
Valve spring compressor, any idea of collet size and throat dimensions. Seen some with 25 and 30mm collets and throat dimension of 140-160mm any good? :y
I found that one like this http://www.ebay.co.uk/itm/10-pcs-Car-Motorcycle-Valve-Spring-Compressor-Tool-Bit-Set-UK-SELLER-/261313098765?hash=item3cd779740d:g:RZcAAOSwPcVVhDCN  did a good job.
It's hard to argue with the price.
Cheers for the link Nick, looks good for the price and adaptable :y :y :y
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
MOT passed. :D
4 advisories for "Vehicle structure has slight corrosion". One for each corner.
Out with the Bilt Hamber stuff soon, methinks.
EMD
Covered it over again properly , 4 ratchet straps and about 12 bungee straps should hold it  :) Not even the cats can get underneath it now  ::)
Omegatitis
Quote from: Kevin Wood on 12 January 2016, 21:02:33
Went out and "tried to bed them in". :-X
There's a funny smell. ::)
I had meself some fun yesterday as well, and chocked on an acrid smell.
Today, brakes work fine, tyres have decided that grip is for wimps  :'(
Quote from: Lazydocker on 23 November 2015, 20:58:13
Quote from: Mr.OmegaMan on 23 November 2015, 00:09:03
Quote from: Kevin Wood on 22 November 2015, 23:35:58
Quote from: Lazydocker on 22 November 2015, 23:09:21
Quote from: Kevin Wood on 22 November 2015, 21:42:18
Quote from: Lazydocker on 22 November 2015, 14:25:36
Quote from: EMD on 22 November 2015, 14:03:49
Fitted the heated over seat , now i have heated legs and back together with a control switch for multiple massages  :)
I'm in the market for one for the van... Which did you get and is it any good?
They had them for £10 in ALDI the other day. Nearly bought one for the roller skate, but decided I'd get laughed at. ::)
Crap.... Did they? Looks like I need to try and pop into a few different Aldis then to try and find one ::)
Yep. Certainly looked worth a punt too. :y
https://www.aldi.co.uk/en/specialbuys/thur-19-nov/product-detail/ps/p/heated-car-seat-cushion/
Grabbed one of these... Can't grumble for the price :y
Just to revisit this... Still works. It's taking a lot of abuse as I'm in the van a lot at the moment. Only criticism I have is that there is very little difference between low and high and, much like setting 5 on Facelift seats, can get a bit too hot!
But, for the price, it is a fantastic investment.  :y
deviator
Another exciting night, new pads up front. 1-2mm left. It was cold.
EMD
Fitted outside temp sensor and led display , the one from lydl ...to the bus  :P
Omegatitis
biggriffin
Drove to nec today, with a spirted drive, noticed a few times, back end was loose on corners, and bit of turn in oversteer,  Whoops tyre pressures all over the show :-X
Hoof'land storeman.
Quote from: biggriffin on 14 January 2016, 18:23:24
And you a lorryist and all ::)
YZ250
.......noticed a few times, back end was loose on corners, and bit of turn in oversteer,  Whoops tyre pressures all over the show :-X
Same here, mine is a rim leak on one wheel so without a refurb I'm buggered.  :'( It will stay at the same psi for a few days until the wheel rotation lands on the bad bit and it will drop to around 11psi overnight. I'll have to get it sorted as it's pissing me off keep inflating it.  >:(
I failed my walk-around checks this morning as it was down again and I felt it rather than see it.  ::)
Quote from: YZ250 on 14 January 2016, 21:22:45
That's when you park it with the passenger door adjacent to your front door, right? :-[
Broke it... :-[
Well actually broke the £250,000 Sideloader hilift at work... Closed the door and the double glazed panel shattered on one side :o
Quote from: Harris K Telemacher on 14 January 2016, 23:42:19
Broke it... :-[
That's your NCB stuffed then!  ::)  ;D
Broke it... :-[
Well actually broke the £250,000 Sideloader hilift at work... Slammed the door shut in a fit of pique and the double glazed panel shattered on one side :o
You must learn to control yourself, young man.  :)
Quote from: STEMO on 15 January 2016, 07:44:00
Broke it... :-[
Not at all feeky chucker :P... it's impossible to slam as it's on an almighty gas strut... besides, if that were the case the door glass would have gone... ;)
