Found it :)
Now I need to find Mr Gixer to recover my battery charger, as I need some electricity. Again. ;D
Quote from: RumpelStiltSkin on 25 February 2017, 17:07:51
Found it :)
It spends so much time plugged into the mains you might as well buy a milk float :-X :P ::) :D
Quote from: Lazydocker on 25 February 2017, 17:17:23
Found it :)
It'd be faster...
Lack of use, and poor starting do not do it any favours.
Topped up the Battlebus with electricity today. Needs topping up again, as all the electricity drained away when I went to start it, having to shuffle cars around for tomorrow.
EMD
Need to sand the bonnet as the lacquer is making a more drastic bid for freedom  :D
Omegatitis
Elite_L0ver
Up and running again thanks to JamesV6CDX and his Magic 🙌 One happy man :y
Although not looking forward to the alarm at 0330 am tomorrow :-[
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Quote from: Doctor Gollum on 28 February 2017, 13:47:31
Booked it in for it's MoT...
Which it passed 8)
Only 7 advisories although it left the garage with only 6 outstanding...
Front to rear brake pipes corroded
Rear brake hose starting to deteriorate x2
Handbrake imbalance, (OS is a touch weak)
NSR ARB link slight play
Rear heat shield loose
OSR tyre valve leaking (only showed up because I had had it washed on way to test...)
Had the tyre valve done, they actually ended giving the beading surface a scrub and polish too, and left £70 lighter... the rear droplinks, brake hoses and handbrake can wait and will all be done at the same time. Undecided how best to trackle the brake pipes, but a smear of copplerslip should suffice for now.
I wonder if the purchaser of that S Class will be so fortunate  ::)
2boxerdogs
Used plenty of fuel,popped over to Cambridge to look at a couple of cars with a mate, took the Merc gave it some real welly there & back really has got some grunt ! 😉
Migv6 le Frog Fan
Started to remove n/s/f strut, to pinpoint the source of knocking. 15 minutes later the heavens opened, and the rain has only now stopped as its got dark.  >:(
Quote from: Doctor Gollum on 28 February 2017, 16:20:12
Which it passed 8)
I got two(although there were two failures): NSF tyre wearing slightly on the inner edge, and a noisy rear wheel bearing. Which will annoy me on holiday, but I don't have time to replace it before we go.
The bloke from Autoglass has just left, after fitting a new windscreen.
He was excellent; prompt, competent and professional.
The company are the opposite, and are best avoided.
Quote from: Nick W on 04 March 2017, 10:39:29
They are the preferred provider for most ins cos though, and you pay extra for using anyone else.
Zirfeld
#13858
Short version
Today I did a hole.
And a replacement sheet.
At last I did some welding.
It was a very nice afternoon!  8)
https://s21.postimg.org/nxxidr0g7/IMG_7677.jpg
https://s10.postimg.org/daywexnu1/IMG_7665.jpg
https://s10.postimg.org/6e8vqhqs9/IMG_7680.jpg
I am not forced to drive an old Omega. I simply like it.
Had a couple of screens via them, when they eventually get the right screen (last one was a Genuine GM one from Germany) and you get a good fitter then I rate them. Autowindscreens when they were trading were absolutely **** on the two occasions, although when they finally got a screen after three months (Pilkington special order) and they found a fitter who'd done Omega's before then the result was good.... shame the car got rear ended a few moths later.
