Quote from: RumpelStiltSkin on 20 February 2017, 17:15:32
Quote from: Entwood on 20 February 2017, 17:11:33
Quote from: Doctor Gollum on 20 February 2017, 16:45:23
It can only go to the compressor or the bulkhead. Unfortunately for you, the bulkhead means buried at the back of the 246 head :-\
Looks like it follows a somewhat convoluted path to the compressor, and if memory serves .. it is attached to the other pipe at the compressor by a large alloy block that forms the seal ... so probably beyond my capabilities ...  :(
As I'm naturally distrusting of the vast majority of A/C "specialists", I'd give Serek a call, and have a nice day out in Huntingdon
That's not a bad idea at all .. IF he can get hold of the bits ... and I could have the lambdas moved at the same time .....  hhhhhh :y :y
TD
Carnt remember if I gave you the number of the mobile aircon guy ive used before....and if I did, don't know if you used his services or not  :-\
Elite_L0ver
Mot day and passed with a few advisories  :-[
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Quote from: TD on 20 February 2017, 18:17:49
Yup .. he's the one who pressure tested it, declared it good, filled it.. and it all leaked out over 2 months ... :(  Seems he only pressure checks to 5 bar.. the system can get up to 15 bar when working I'm now told, so his check wasn't really enough .....
He also said he was not willing to do any mechanical work on an omega as it comes under the heading "too bloody difficult" ....   :(
Shackeng
Quote from: Entwood on 20 February 2017, 21:15:30
Spooky Nige, my 3.2 has what sounds like the same failure, and the guy we are talking about identified the pipe, which sounds like the same one. He was actually doing jobs under contract for Skurrays Now VX at the time! Perhaps we should both go to Sereks, and get a job lot ;D
Its been a while since I did one but I recall that the large flange you talk of is not even connected to the pipes, it simple slides over them and acts as a clamp, so worth a double check
minifreek
Hooked up the tintent and dragged it halfway up the country to the middle of a field.....
Happy days to be had :)
D.I.L.L.I.G.A.F...
Migv6 le Frog Fan
Quote from: Marks DTM Calib on 21 February 2017, 09:18:24
If my memory serves - the clamp is held in place by a single torx screw, in the centre, between the pipes.
Quote from: Migv6 on 21 February 2017, 10:31:00
Two pipes, different sizes, both have flanges on them, the seals "butt" up against the inside edge of the flange, the flanges are then pulled tight onto the filter/dryer by a large block that pulls on the outer edges of the flanges by a single bolt through the whole caboodle. The larger flange is cracked 80% of the way round now and simply will not pull the seal in tight enough.
EMD
Quote from: Elite_L0ver on 20 February 2017, 18:51:23
Let me guess  :) :
Rear tyres low tread  :-\
Oil leak  :-\
Coolant leak  :-\
They are the usual culprits  :D
Omegatitis
Got filthy painting the bottom of the engine with gunk then scrubbing and rinsing it off to aid this oil leak identification
Migv6 le Frog Fan
Finished welding the 190 back together.  :)
Elite_L0ver
Quote from: EMD on 21 February 2017, 12:00:20
Let me guess  :) :
Oil leak  :-\
Coolant leak  :-\
No none of those as it had fairly new tyres no oil lleak no coolant leak
These:-
Also had to rev the tits off it to pass emissions
And now the wifes zaffy needs a new cv joint and mot :'( :-*
Migv6 le Frog Fan
If you take the sill covers off you may well find they are rotten as a pear. Buy a MIG welder and get stuck in. Ive just done it, and its not that hard.  ;)
Elite_L0ver
Would need to be added to the list of jobs so far that are
*MOT SWMBO ZAFFY*       ( keep her happy i can be left alone to do:-)
1) Cambelt kit and waterpump change
2) rocker gasket change inc new plugs
3) Mot Repairs
4) Sort NSF Knocking intermittent!! :-[ :-[ :( >:( :y
On the Plus side fitted a nice new DAB BT CD Radio to SWMBO Car :y
