John-R
Posted separate about this, but I finally removed the Power Sounder and hit it with a hammer.
Batteries actually looked OK - no leaks - but as advised by EVERYONE on here - time it went after it started beeping when ignition switched off.
Secondly. I want to prevent my coil pack from disintegrating from the usual water drips from the scuttle.
I notice the bottom seal on the windscreen has come away which I believe may not help the problem.
What's the best stuff to use to re-seal it ?
You can pick your friends and you can pick your nose . . but you can't pick your friends nose !
twiglet
Bought another one!  ::) Collect it on Sunday...  ;D :y
henryd
Quote from: twiglet on 10 October 2012, 14:00:48
What flavour this time ??? :D :D :D
other rides
twiglet
Quote from: henryd on 10 October 2012, 14:17:53
It's a 3.2 Elite saloon, which needs a bit of work.  A good friend of mine has been after one for a while, but doesn't have a very big budget, so I'm hoping to get it back up to it's former glory and then let him have it.  :y
henryd
Quote from: twiglet on 10 October 2012, 14:40:43
Nice one :y
other rides
It's a 3.2 Elite saloon, which needs a bit of work.  A good friend of mine has been after one for a while, but doesn't have a very big budget, so he can go fook himself,Im going to break it.  :y
Thought so. ::) ;D ;D
henryd
Quote from: Albitz on 10 October 2012, 16:38:06
PMSL ;D ;D ;D
other rides
Quote from: John-R on 10 October 2012, 10:36:22
Apparently using the hammer on it is quite satisfying  :-\ :-\ :-\
Swapped battery on the Cavalier for a freshly charged one again.Fresh one is now flat as a witches tit a few hours later.Looks very like I have a battery drain to track down. :( Shouldnt be that much on  Diesel to drain the battery I wouldnt have thought. :-\
Removed the dispack from the breaker.
Drove my own Omega,and wondered what the humming noise is which seems to be coming from n/s/r,which goes away when the brake pedal is depressed.Sticky caliper/worn pads/handbrake shoes or linkage come adrift and stuck somewhere ? :-\
Not a good day all in.Nothing constructive achieved really. :(
Also spent quite a while in supermarket car parks,which never exactly cheers me up. :-X
Quote from: Albitz on 10 October 2012, 19:15:04
Glowplugs? Not unknown for the contacts in a diesel's glowplug relay to weld themselves together.
Might be worth a look,thanks. Im a newbie with diesels tbh. :y
As it's a Cavalier i'd check the boot lamp switch.
