twiglet
Quote from: Albitz on 10 October 2012, 16:38:06
Quote from: twiglet on 10 October 2012, 14:40:43
Quote from: henryd on 10 October 2012, 14:17:53
Quote from: twiglet on 10 October 2012, 14:00:48
Bought another one!  ::) Collect it on Sunday...  ;D :y
What flavour this time ??? :D :D :D
It's a 3.2 Elite saloon, which needs a bit of work.  A good friend of mine has been after one for a while, but doesn't have a very big budget, so he can go fook himself,Im going to break it.  :y
Thought so. ::) ;D ;D
That will, of course, be plan B if the car turns out to be too far gone...  ;)
Quote from: Albitz on 10 October 2012, 22:41:33
Will check that too,cheers. :y
If you need another pair of eyes/a hand, give me a shout ;)
Radar
Changed the dispack - (don't want to do that again in a hurry) and removed the power sounder. It got dark so will have to follow with assembling back wipers/scuttle.
Quote from: Lazydocker on 11 October 2012, 10:48:45
Will do Paul.Thanks. :y
Im suspecting the alternator.Twiglet had very similar problems with the car a couple of years ago* and it turned out to be the alternator.I think the alternator has about 5 weeks warranty left,which could be handy,as they are pretty expensive I believe.
Have unplugged the bootlight switch,so will see if that helps.I noticed just now that the dash lights stay lit (dimly) when I take the key out,dont know if that points to anything ?
http://www.omegaowners.com/forum/YaBB.pl?num=1296594685/0*
I just tried using a jump lead from the battery negative to the engine block.It seemed to spark a lot  (which was a bit of a surprise) but the engine turned over as normal and it fired up straight away.This leads me to think it has an earthing problem ?
henryd
Quote from: Albitz on 11 October 2012, 12:36:23
Battery neg to engine block shouldn't spark at all so yes check earth points on body and lump :y
other rides
I think I will have a look at the engine earth strap first and then go from there. :y
twiglet
Quote from: Albitz on 11 October 2012, 14:17:58
Or I would if it had one. :D ;D
I suspect you may have found the problem then...  ;D
Well,I certainly couldnt find an engine earth strap.Maybe an old fashioned concept ? My Viva definitely had one. ;D
Ahh, the old "grounding through the throttle cable" trick. ;D
Might try fitting an earth strap from the engine to the chassis,and if it solves it,all well & good. :-\
twiglet
There should be one that goes from the engine block to the n/s/f chassis leg... flat braided steel, about 5 inches long.  :y
Couldnt see it,but will have another look.Hopefully before I go to work. :y
twiglet
Should be easy to see from underneath.  :y
