Found it. :y...........it hasnt just broken,its melted through at the point where it bolts onto the gearbox.Looks like someone has been at it with an oxy-acetlene torch. :o
That explains the "bad earth" problem,but why has it melted ? Its not a little 2 mm wire. ???
twiglet
Well I guess it's 1 of 2 reasons...
1.  The braids had started to break, and the current had less of a path, which caused it to overheat and melt.  Possibly combined with some arcing.
2.  The alternator is putting out to much current, and is burning things out.  The alternator I replaced on it 2 years ago was putting out over 17 amps.  However, after I replaced it I checked all the wiring, and everything was ok.
Have you checked the output at the alternator yet?
henryd
Quote from: Albitz on 11 October 2012, 15:41:00
Nope.How dodatden ?
Fix that earth then run t'engine and check output voltage from alternator main lead :y
other rides
henryd
Quote from: Albitz on 11 October 2012, 17:31:11
Thanks Henry.Will do. :y
I suspect the lack of proper engine earth is the cause of you seeing 17v of charge ;)
other rides
twiglet
Quote from: henryd on 11 October 2012, 17:41:29
Don't know Henry.  I checked the earth straps before I replaced the alternator, and they were fine back then (this was 2 years ago).  Fitted new alternator which provided charging voltage of 14.4v.  I managed to return the original alternator under warranty to the supplier, and they confirmed it was faulty.  :-\
twiglet
Just realised in my post #3526 above, I was rabbiting on about the alternator producing 17 amps. Of course, I meant volts... Been one of those days...  :-[
henryd
Quote from: twiglet on 11 October 2012, 17:57:34
Aye, it may be goosed but it still needs that earth back on :y
other rides
Replaced the interior from my CDX to my GLS today, including carpet and sound proofing due to a blocked scuttle drain, I really don't want to do that again ever :(
Found this buried at the back of the garage....
Even seems to be the right colour ::)
Manual Elite V6
Today I fitted a new aeriel lead (kickpanel to headunit) thanks to Albitz and now have a radio again, though only took me 15 minutes to fit as I routed it differently this time.  :y
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
Drift Tramp
Pulled the engine out of my skyline today. Forge time me thinks.
phill osey
Lee here, I personally have done nothing  :P
but Phil has been playing about under the bonnet, and found out that the cause of 1 of our problems is the crank sensor... now off to find out which type we have, as someone told us there are 2 different ones... then find where we can get one
love my Omega
henryd
Quote from: phill osey on 12 October 2012, 12:05:30
Buy it from a Vauxhall dealer,pattern ones are'nt worth the pain :y
other rides
