Author Topic: So what have you done to your car today?  (Read 5864918 times)
0 Members and 20 Guests are viewing this topic.
« Reply #8925 on: 09 November 2014, 09:57:09 »
Noticed that the project had a lot of condensation in the pas side window. Then found that the carpets where soaked in drivers footwell, and that water was coming in through the hole where the stearing box once was.
Bollards! That's going to stink for ever more now.  >:(  :'(
Dehumidifier now running flat out.
Get tunnie over, he's a whizz with gaffer tape ;D
Then the Top Gear Botswana team to drain the footwell ;D
May be worth removing carpet and sound deadening, to dry it properly.
« Reply #8926 on: 09 November 2014, 13:16:52 »
Most definitely, or else it will stink as the sound deadening holds alot more water than people give it credit for...
4x4
« Reply #8927 on: 09 November 2014, 13:51:17 »
Fitted new flashing amber lights to roof rack,front all connected,and mounted to roof rack,rears need cables extending so a job for 1 evening.
« Reply #8928 on: 09 November 2014, 14:26:14 »
Struggling to change oil on the Battlebus, as my jack is in a location in the garage that's currently not easily accessible (still got a load of furniture in it).
Anyways, with the help of a nearby kerb, draining all done, move on to oil filter. 'dangle berries', I melted my 36mm socket last year. Off to Bicester to get another. Broke the Bullet. 'dangle berries'.
« Reply #8929 on: 09 November 2014, 16:27:06 »
Removed plenum and inlet manifold.  Looked at the wet oily mess on and around the oil cooler plate and dabbed at it with some bog roll.  ::)
Put it all back together again.  :y
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #8930 on: 09 November 2014, 17:07:45 »
Fitted front drop links to both sides of the car, trying a non gm part this time as they were cheap, and if they dont last then i havent lost too much. The parts are made by First Line, we shall see if they are any good.
Fitted bosch aero twin flat blade wipers to replace the GM flat blades that were worn out after 9 years, huh, ''stuff dont last these days''. ;D
Gary
Jaguar XJ6
« Reply #8931 on: 09 November 2014, 18:11:20 »
Removed plenum and inlet manifold.  Looked at the wet oily mess on and around the oil cooler plate and dabbed at it with some bog roll::)
That'l fix it  :D :'(
« Reply #8932 on: 10 November 2014, 09:09:48 »
Found out last night that if you're really pissed off it's possible to get the Ranger quite sideways in 2WD mode, and it corners a lot faster than I'd have expected.
« Reply #8933 on: 10 November 2014, 10:55:31 »
Mind you don't roll it... ::)
« Reply #8934 on: 10 November 2014, 11:00:56 »
Discovered that the heater fan has stopped working in the Desmond  :'(
« Reply #8935 on: 10 November 2014, 11:05:34 »
At the time I'm not sure I'd have cared, Al - as long as it didn't roll over onto anyone else, anyway
« Reply #8936 on: 10 November 2014, 11:06:31 »
Desmond  :'(
How long have I been here? I just got that.. :-X
« Reply #8937 on: 10 November 2014, 11:16:45 »
Gary
First Line are crap.....just so you know for when the knocking returns, item of choice is a Meyle HD part...  :y
« Reply #8938 on: 10 November 2014, 11:35:22 »
Desmond  :'(
It must have been lost in the orange glow of the curry house car park... you walked past it twice ;D
« Reply #8939 on: 10 November 2014, 11:37:35 »
Desmond  :'(
 ;D No I meant the Desmond part.. Desmond Tutu, tutu, two two, 2.2..
