Project Tractor engine swap
Started by TheBoy, 18 August 2007, 23:20:02
Quotehmm kind of expected that >:( when we moved the pump the extra mm and it didnt improve it any further, should have reset it to the second or third position it was best there i think, did you try a hot start? was it ok? how much smoke now? damn i can see me going round again to get it dead right!!!
mrs Omegatoy wasnt to mad really  :o as she informed me that i had bought her a new phone!!!! :-* for being so late, fancy hurting a guy in his wallet? thats only just slightly better than the ear bashing i was expecting!!! :'(
Stopped at Tunnie's for about 30mins, started fine then.  It was dark, but could see a little smoke as I passed the streetlights when caning it.
Shall I get that broken socket replaced so we can do piezo injector up, or see about refund and try and get Draper set from somewhere?
The strange rattle when I first went on test drive went after while.  Hopefully the lifter treatment will start to work if it is tappets.  I'm not sure if its tappet or diesel knock noise?
On the driveway, if I revved it, bit get a fair bit of smoke - it disappeared under MV6 and appeared behind that. Probably too much smoke...
QuoteUnder load, its a loud tickety noise
If the rattle is sensitive to load it's unlikely be tappets I'd say. More likely timing related or an exhaust blow perhaps?
Take your foot off at 70mph ::), and its nearly quiet.
Oh, and Omegatoy, guess who forgot to put the wipers on ::) - you try washing your windscreen at silly speeds, only to find there is nothing to wipe the screen ;D.  I should know better - I did the same to MaxV6 earlier this year  :-[
Omegatoy
Think we should tighten the piezo injector but also think you should put a few hundred miles on it before we go doing anything else to see if it settles down after clearing its throat so to speak, slight power loss could be down to extremely flat inlet gaskets allowing a small boost bleed off? also think should blank egr off to see if it restores your performance ;D but all that can be done later just good to see you driving the thing without causing a water shortage again :y
Yeah, need to flush coolant through a few times - donor car probably didn't have much antifreeze in by look of things.  Don't want to do another oil change until that lifter treatment has had chance to work - or should I consider putting more in?
I'll get that socket replaced tomorrow if Motorserv are open, so any time you have 10mins, drop me a text :y.  An experienced ear on the remaining noise, and perhaps a test drive?
Omegatoy
note to self, if the boy offers to fit a part on my car, go round behind him and tighten everything he does up!!!!!! ;D
After everything I said, you can imagine what a dork I felt when I realised  :-[
Auto Addict
;D ;D ;D ;D
Glad you're getting there TB :y
I like red cars
Markie
;D ;D done that before - quick test drive of Bob Dents old estate after dis pack swap saw me caught in a down pour and no blades...
Good news at last on this one.....maybe next weekend we have a double celebration  - perfect running tractor and Vectra v6  :D
LFF64
Ha ha so Tunnie has competion in breaking things  ;D
QuoteGood news at last on this one.....maybe next weekend we have a double celebration  - perfect running tractor and Vectra v6  :D
I think thats pushing the truth a little ;D
Dazzler
Glad to hear its running at last ;) Have you tried running Forte via the filter?? This should reduce the smoke a fair bit.
QuoteGlad to hear its running at last ;) Have you tried running Forte via the filter?? This should reduce the smoke a fair bit.
Half filled the fuel filter with Diesel Magic (as recommended by Omegatoy).  Could possible do with another dose once I've done a few miles.
happy to hear its working ok  :y
Unfortunately, the rather thing is jinxed.
Yesterday was obviously just a fluke.
If you can start the heap, it runs awful, lumpy, smokey, noisy.  No amount of pump adjustment dials it out today.
Both Omegatoy and I are entirely out of ideas now.
Time to call the local scrappy for collection methinks.
