Had a new, genuine GM heat reflective, rain sensor windscreen fitted to the 3.2. Many thanks Autoglass.  :)
Removed front bushes from a new pair of Lemforder wishbones ready to fit poly bushes... All for the next project car.
EMD
Omegatitis
Realised I've done over 10,000 miles since I bought it in April. Haven't had to renew the brakes, cam belt, clean the breathers, etc. etc.........
Changed the oil & filter on the 3.2, really needed doing. Fixed a rattly exhaust, back box to centre section crush thingys not as tight as they should be.  :-\
Normally an exhaust fuses together and is one lump of metal, could easily loose the bolts, adjust and tighten up. The ETS exhaust is lasting really well, no signs of rusting or corrosion.
Fixed bonnet catch too, not quite right. Also put a new battery on it, topped up screenwash fluid and power steering fluid.
MOT tomorrow, first time not using local Brackley place for about 10 years.
Gave 2.2 a once over, all good there. It's been clocking the miles over the winter, as not using the bike.
biggriffin
[/img]
After changing the above, I had a spirited drive home from work, difference was noticeable, rear didn't want to break away as normal on some bends, and entry and exits were better, so yes an improvement. :y
Hoof'land storeman.
dazza88
Fixed the up and down thing on the passenger seat and put a middle box and a new rear back box also front discs and pads also 2 new sensor wear things for pads  :y
2002 2.2 cd auto             mrk2 astra gte
vauxhall colton               vauxhall omega 2.6 v6 auto
ford sierra saphire 20l   vauxhall omega 2.2 dti 02 plate
Washed it.
Which was a surprise for both of us ;D
3.2 passed MOT, no advisories. At a new 'Vauxhall Specalist' in Camberley, first time with no advisories. As my old chap always liked something on the list. As TheBoy well knows  ::)
Quote from: tunnie on 29 December 2015, 13:29:55
What on earth are you referring too? :-X :-X :-X ::) ::)
jimbo125
Interesting what "specialist" in Camberley?
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
minifreek
Took delivery of the steering arm :)
Will be possibly fitting it tomorrow, depends if I get chance between sorting out a new build PC for my son and the weather.....
D.I.L.L.I.G.A.F...
gbh
Well it took a while but I fitted a towbar from tow trust tv339 and thanks to a member for the towbar and guidance from forum its done.I just need to test the electrics,my friend has a small trailer so that should do it.
Quote from: jimbo125 on 29 December 2015, 23:16:15
Fox.
On Doman road  :y
Should add it's "new" for my 3.2 rather than new as being established  ;)
jimbo125
Quote from: tunnie on 30 December 2015, 22:58:19
Oh that clears that one up cheers
Fox.
On Doman road  :y
They were very helpful. I did want it MOT'd before Christmas, but fully booked. So went in first slot they had on the 29th, said it would take about an hour and they were spot on.
Will take my 2.2 there now as well I think, so handy as its within walking distance. All my tools are here now, so does not make sense to go back to my parents to use MOT there, as I do like to support individual small businesses.
