smalt36
Fitted io play2 hands free and repaired TID with a zafira one :y
Quote from: biggriffin on 28 December 2015, 19:24:37
[/img]
After changing the above, I had a spirited drive home from work, difference was noticeable, rear didn't want to break away as normal on some bends, and entry and exits were better, so yes an improvement. :y
Just bedded in by looks of it ;D
Quote from: Lazydocker on 29 December 2015, 21:29:50
Quote from: tunnie on 29 December 2015, 13:29:55
3.2 passed MOT, no advisories. At a new 'Vauxhall Specalist' in Camberley, first time with no advisories. As my old chap always liked something on the list. As TheBoy well knows  ::)
What on earth are you referring too? :-X :-X :-X ::) ::)
And what is that supposed to mean, Glassback?
Besides, I'm over it
Quote from: TheBoy on 31 December 2015, 17:36:02
I have no idea... I was asking the student what he meant :-X  ;)
that's a euphemism I never expected to see in the same sentence as 'MOT' test. :o
2boxerdogs
Just driven it !! Only use the Merc on dry days lovely & sunny here for most of the day so had a run over the border to Cambs  , I just love the V8 should have bought one years ago.
Quote from: Lazydocker on 31 December 2015, 19:53:04
Clearly Santa brought you a bigger spoon  :-X
GastronomicKleptomaniac
Started off by buggering up the Special. Two steps forward, eight steps back... then was prevented from buggering up the MV6 by the female of the household. Her cunning tactic? To disappear off to work, with the brake pipe fittings she bought the other day,  firmly ensconced in her handbag. I love her but she is a little frustrating at times  ;D
Removed MV6 LSC rear springs, levelling sensors with loom and fake Irmscher grill from the 2.6.
Also attempted to remove front shocks and springs but the light was failing in the barn (no electric) and I think I'm gonna need a bigger spanner....  ;D
Quote from: VXL V6 on 01 January 2016, 17:01:57
Plusgas. Best invention ever.
Lots of Plusgas used  ::) :(
It's the top mount that's the problem - I think the B4's use a Nylock nut which doesn't help. Problem is I cant use a socket and bar because the hex needs to be held so the shock doesn't spin...
Quote from: GastronomicKleptomaniac on 01 January 2016, 18:12:25
7mm hex and a 24mm deep ring spanner... Job jobbed ;)
Quote from: VXL V6 on 01 January 2016, 18:37:35
I refit the original nuts rather than the nylock ones...
Ah, I see your point. Halfords do do a "shock and unlock" spray that I've used to good effect, but not sure how effective it will be on Nyloc... :y
