Quote from: Harris K Telemacher on 01 January 2016, 18:39:33
Quote from: GastronomicKleptomaniac on 01 January 2016, 18:12:25
Quote from: VXL V6 on 01 January 2016, 17:01:57
Removed MV6 LSC rear springs, levelling sensors with loom and fake Irmscher grill from the 2.6.
Also attempted to remove front shocks and springs but the light was failing in the barn (no electric) and I think I'm gonna need a bigger spanner....  ;D
Plusgas. Best invention ever.
7mm hex and a 24mm deep ring spanner... Job jobbed ;)
Strangely I do know what tools to use. I need a longer spanner so I can get some torque on it.
32 mm spanner interlocked should do it ;) gives you about 70 cm leverage...
biggriffin
Quote from: Harris K Telemacher on 01 January 2016, 22:20:56
Decent battery powered windey gun undo top nuts.
Hoof'land storeman.
Quote from: biggriffin on 02 January 2016, 08:15:48
Exactly. And large nyloc nuts are one of the reasons to justify even a cheap cordless windy gun.
Problem is that you need to stop the shock spinning with a hex so anything that totally covers the nut is no use.
Quote from: VXL V6 on 02 January 2016, 10:08:58
It's  not rocket science, use a spanner on the nut and turn the shock hex with your ratchet/windy gun**. You do need a good quality Allen socket, but that's true for any internal drive bolt.
**I see Al suggested this several posts ago
If you need a hand with anything one weekend, VXL V6, just shout :y
Give the dark evenings, I don't think after work would be productive.
Quote from: Nick W on 02 January 2016, 10:26:33
Ah I follow now, sorry for the confusion.
Quote from: TheBoy on 02 January 2016, 10:46:33
Cheers TB, I'm getting there slowly. Just want to liberate the 40K MV6 front springs and poly bushes then everything else is simple stuff I've done before - bonnet, bumper and anything else I discover I need.
Car51
Bloody cold now but I've just removed 140ml of water from 2,4 and 6 plug wells then finished the job off by sealing the scuttle.  :y
EMD
Feeling sorry for the fast black one just sitting there rotting away . On the plus side its not racking up any more mileage  :)
Omegatitis
Over the last few days I have watched Mark do an oil cooler on the omega and a cambelt kit on the zafira. Thanks very much Mark. Much appreciated :)
Fitted new brake flexis and pipes to the front. Wondered why there was fluid pouring out when brake applied. Rescued old flexis from bin, transferred copper washers onto new flexis, refitted. Had celebratory cuppa. Bled brakes... now have a working MV6. I give it three days before he throws his dolly out of the pram again...
Now to buy a small tin of Z157 paint and give the rear arch a pikey paintjob, on the basis that I could glue some foil to it and it would look better than it does now...
joff
Just took the roof box off the estate after our 800 mile round trip to Scotland over Christmas. The Elite now needs a bloody good clean and service plus a few other jobs. BuT first have to put the gearbox back in the wife's Discovery after the flexi plate snapped on me.
Discovered that three days was an overestimate.  Road trsted after brake work, parked up, went to start it a while later and the crank sensor has decided that the time to give up is when im slap bangin the middle of the drive,  blocking all the other cars in... youve gotta laugh! :D
